The optional-data union occurs so frequently that it is given a special syntax of its own for declaring it. It is declared as follows.
type-name *identifier;
This syntax is equivalent to the following union:
union switch (bool opted) { case TRUE: type-name element; case FALSE: void; } identifier;
The optional-data syntax is also equivalent to the following variable-length array declaration, because the Boolean opted can be interpreted as the length of the array.
type-name identifier<1>;
Optional data is useful for describing recursive data-structures, such as linked lists and trees.
