System Administration Guide: Basic Administration
The analyze Menu
The analyze menu looks similar to the following.
format> analyze
ANALYZE MENU:
    read     - read only test   (doesn't harm SunOS)
    refresh  - read then write  (doesn't harm data)
    test     - pattern testing  (doesn't harm data)
    write    - write then read      (corrupts data)
    compare  - write, read, compare (corrupts data)
    purge    - write, read, write   (corrupts data)
    verify   - write entire disk, then verify (corrupts data)
    print    - display data buffer
    setup    - set analysis parameters
    config   - show analysis parameters
    quit
analyze>
The following table describes the analyze menu items.
Table 35–4 Descriptions for analyze Menu Item
Sub-Command
Description
read
Reads each sector on the current disk. Repairs defective blocks as a default.
refresh
Reads then writes data on the current disk without harming the data. Repairs defective blocks as a default.
test
Writes a set of patterns to the disk without harming the data. Repairs defective blocks as a default.
write
Writes a set of patterns to the disk then reads the data on the disk back. Destroys existing data on the disk. Repairs defective blocks as a default.
compare
Writes a set of patterns to the disk, reads the data back, and then compares it to the data in the write buffer. Destroys existing data on the disk. Repairs defective blocks as a default.
purge
Removes all data from the disk so that the data can't be retrieved by any means. Data is removed by writing three distinct patterns over the entire disk (or a section of the disk). If the verification passes, a hex-bit pattern is written over the entire disk (or a section of the disk).
verify
Writes unique data to each block on the entire disk in the first pass. Reads and verifies the data in the next pass. Destroys existing data on the disk. Repairs defective blocks as a default.
print
Displays the data in the read/write buffer.
setup
Lets you specify the following analysis parameters:
Analyze entire disk? yes
Starting block number: depends on drive
Ending block number: depends on drive
Loop continuously? no
Number of passes: 2
	Repair defective blocks? yes
Stop after first error? no
Use random bit patterns? no
Number of blocks per transfer: 126 (0/n/nn)
Verify media after formatting? yes
Enable extended messages? no
Restore defect list? yes
Restore disk label? yes
Defaults are shown in bold.
config
Displays the current analysis parameters.
quit
Exits the analyze menu.
