System Administration Guide: Basic Administration
The defect Menu
The defect menu looks similar to the following:
format> defect
DEFECT MENU:
        primary  - extract manufacturer's defect list
        grown    - extract manufacturer's and repaired defects lists
        both     - extract both primary and grown defects lists
        print    - display working list
        dump     - dump working list to file
        quit
defect>
The following table describes the defect menu items.
Table 35–5 The defect Menu Item Descriptions
Sub-Command
Description
primary
Reads the manufacturer's defect list from the disk drive and updates the in-memory defect list.
grown
Reads the grown defect list, which are defects that have been detected during analysis, and then updates the in-memory defect list.
both
Reads both the manufacturer's defect list and the grown defect list, and then updates the in-memory defect list.
print
Displays the in-memory defect list.
dump
Saves the in-memory defect list to a file.
quit
Exits the defect menu.
