Programming Interfaces Guide
Using lgrp_init()
The lgrp_init() function initializes the lgroup interface and takes a snapshot of the lgroup hierarchy.
#include <sys/lgrp_user.h>
lgrp_cookie_t lgrp_init(lgrp_view_t view);
When the lgrp_init() function is called with LGRP_VIEW_CALLER as the view, the function returns a snapshot that contains only the resources available to the calling thread. When the lgrp_init() function is called with LGRP_VIEW_OS as the view, the function returns a snapshot that contains the resources that are available to the operating system. When a thread successfully calls the lgrp_init() function, the function returns a cookie that is used by any function that interacts with the lgroup hierarchy.
The lgroup hierarchy consists of a root lgroup that contains all of the machine's CPU and memory resources. The root lgroup may contain other locality groups defined by bounded latency intervals.
The lgrp_init() function can return two errors. When a view is invalid, the function returns EINVAL. When there is insufficient memory to allocate the snapshot of the lgroup hierarchy, the function returns ENOMEM.
