The steps in this section pertain to only IP layers that are configured by using ifconfig(1M). Layers before or after the IP layer, such as ATM or other services, require specific manual steps if the layers are not automated. The specific steps are used to unconfigure during pre-detach and configure after post-attach. See the layers and applications documentation for instructions on how to handle the failure and DR scenarios.
Recovery after a DR operation for a NIC that is part of the IO board on a Sun Fire platform is automatic. If the NIC is a PCI device, the recovery is also automatic. Consequently, the following steps are not required for a NIC that is coming back as part of a DR operation. For more information on the Sun Fire x800 and Sun Fire 15000, see the cfgadm_sbd(1M) man page. The physical interface is recovered to the configuration that is specified in the /etc/hostname.interface file. See Configuring Multipathing Interface Groups for details on how to configure interfaces to preserve the configuration across reboots.
On Sun Fire legacy (Exx00) systems, DR detaches are still subject to manual procedures. However, DR attaches are automated.
You must do the following manual steps before recovering a physical interface that was not present at system boot. The following procedure uses physical interfaces hme0 and hme1 as example interfaces. The procedure assumes that both interfaces are in a multipathing group. The procedure also assumes that hme0 was not present at system boot.
The failback of IP addresses during the recovery of a failed physical interface last three minutes. This time might vary. The time depends on network traffic. The time also depends on the determination of the stability of the incoming interface to fail back failed-over interfaces by the in.mpathd daemon.
Retrieve the failed network information from the failure error message of the console log.
See the syslog(3C) man page. The error message might be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (moved to hme0) |
The error message might also be similar to the following message:
moving addresses from failed IPv4 interfaces: hme1 (couldn't move, no alternative interface) |
Attach the physical interface to the system.
Refer to the cfgadm(1M) man page, Sun Enterprise 10000 DR Configuration Guide, or Sun Enterprise 6x00, 5x00, 4x00, and 3x00 Systems Dynamic Reconfiguration User's Guide for a description of how to replace the physical interface.
Refer to the message content from step 1. If the addresses could not be moved, go to step 5. If the addresses were moved, do step 4.
Unplumb the logical interfaces that are configured as part of the failover process by doing the following substeps.
Look at the contents of the file /etc/hostname.<moved_from_interface> to see what logical interfaces were configured as part of the failover process.
Unplumb each failover IP address by typing the following command:
# ifconfig moved_to_interface removeif moved_ip_address |
Failover addresses are those addresses that are marked with the failover parameter, or those addresses that are not marked with the -failover parameter. You do not need to unplumb IP addresses that are marked -failover.
For example, assume that the contents of the /etc/hostname.hme0 file contained the following lines:
inet 1.2.3.4 -failover up group one addif 1.2.3.5 failover up addif 1.2.3.6 failover up |
Then, to unplumb each failover IP address, you would type the following commands:
# ifconfig hme0 removeif 1.2.3.5 # ifconfig hme0 removeif 1.2.3.6 |
Reconfigure the IPv4 information for the replaced physical interface by typing the following command for each interface that was removed.
# ifconfig removed_from_NIC <parameters> |
By using the example in step 4, you would type the following commands:
# ifconfig hme1 inet plumb # ifconfig hme1 inet 1.2.3.4 -failover up group one # ifconfig hme1 addif 1.2.3.5 failover up # ifconfig hme1 addif 1.2.3.6 failover up |
