Configuring the Multipathing Configuration File
The multipathing /etc/default/mpathd configuration file contains three parameters that you can adjust
for your configuration requirements:
See Multipathing Configuration File for a description of these parameters.
How to Configure the Multipathing Configuration File
Become superuser.
Edit the /etc/default/mpathd. Change the default
value of one or more of the three parameters by using one or more of the following
substeps.
Type the new value for the FAILURE_DETECTION_TIME
parameter.
Type the new value for the FAILBACK parameter.
Type the new value for the TRACK_INTERFACES_ONLY_WITH_GROUPS parameter.
TRACK_INTERFACES_ONLY_WITH_GROUPS=[yes | no]
On a command line, type the following command.
