This chapter provides information about the Diffie-Hellman authentication mechanism that can be used with Secure RPC.
The following is a list of the step-by-step instructions in this chapter.
Secure RPC is an authentication method that authenticates both the host and the user who is making a request for a service. Secure RPC uses the Diffie-Hellman authentication mechanism. This authentication mechanism uses DES encryption. Applications that use Secure RPC include NFS and the NIS+ name service.
NFS enables several hosts to share files over the network. Under the NFS service, a server holds the data and resources for several clients. The clients have access to the file systems that the server shares with the clients. Users who are logged in to the client machines can access the file systems by mounting the file systems from the server. To the user on the client machine, it appears as if the files are local to the client. One of the most common uses of NFS allows systems to be installed in offices, while keeping all user files in a central location. Some features of the NFS service, such as the mount -nosuid option, can be used to prohibit the opening of devices and file systems by unauthorized users.
The NFS service uses Secure RPC to authenticate users who make requests over the network. This process is known as Secure NFS. The authentication mechanism, AUTH_DH
, uses DES encryption with Diffie-Hellman authentication to ensure authorized access. The AUTH_DH
mechanism has also been called AUTH_DES
For how to set up and administer Secure NFS, see “Administering the Secure NFS System” in System Administration Guide: Resource Management and Network Services.
For how to set up the NIS+ tables and enter names in the cred table, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
For an outline of the steps that are involved in RPC authentication, see Implementation of Diffie-Hellman Authentication.
The Data Encryption Standard (DES) encryption functions use a 56-bit key to encrypt data. If two credential users or principals know the same DES key, they can communicate in private by using the key to encipher and decipher text. DES is a relatively fast encryption mechanism. A DES chip makes the encryption even faster. However, if the chip is not present, a software implementation is substituted.
The risk of using just the DES key is that an intruder can collect enough cipher-text messages that were encrypted with the same key to be able to discover the key and decipher the messages. For this reason, security systems such as Secure NFS change the keys frequently.
Kerberos is an authentication system that was developed at MIT. Encryption in Kerberos is based on DES. Kerberos V4 support is no longer supplied as part of Secure RPC. However, a client-side implementation of Kerberos V5, which uses RPCSEC_GSS, is included with this release. For more information, see Chapter 13, Introduction to SEAM.
The Diffie-Hellman (DH) method of authenticating a user is nontrivial for an intruder to crack. The client and the server have their own private key, which they use with the public key to devise a common key. The private key is also known as the secret key. The client and the server use the common key to communicate with each other by using an agreed-on encryption function, such as DES. This method was identified as DES authentication in previous Solaris releases.
Authentication is based on the ability of the sending system to use the common key to encrypt the current time. Then the receiving system can decrypt and check against its current time. Make sure to synchronize the time on the client and the server.
The public keys and private keys are stored in an NIS or NIS+ database. NIS stores the keys in the publickey map. NIS+ stores the keys in the cred table. These files contain the public key and the private key for all potential users.
The system administrator is responsible for setting up NIS maps or NIS+ tables, and generating a public key and a private key for each user. The private key is stored in encrypted form with the user's password. This process makes the private key known only to the user.
This section describes the series of transactions in a client-server session that use DH authentication (AUTH_DH
Sometime prior to a transaction, the administrator runs either the newkey or nisaddcred command to generate a public key and a secret key. Each user has a unique public key and secret key. The public key is stored in a public database. The secret key is stored in encrypted form in the same database. To change the key pair, use the chkey command.
Normally, the login password is identical to the secure RPC password. In this case, the keylogin command is not required. However, if the passwords are different, the users have to log in, and then run a keylogin command explicitly.
The keylogin command prompts the user for a secure RPC password. The command then uses the password to decrypt the secret key. The keylogin command then passes the decrypted secret key to a program that is called the keyserver. The keyserver is an RPC service with a local instance on every computer. The keyserver saves the decrypted secret key and waits for the user to initiate a secure RPC transaction with a server.
If both the login password and the RPC password are the same, the login process passes the secret key to the keyserver. If the passwords are required to be different and the user must always run the keylogin command, then the keylogin command can be included in the user's environment configuration file, such as the ~/.login, ~/.cshrc, or ~/.profile file. Then the keylogin command runs automatically whenever the user logs in.
When the user initiates a transaction with a server, the following occurs:
The keyserver randomly generates a conversation key.
The kernel uses the conversation key to encrypt the client's time stamp, among other things.
The keyserver looks up the server's public key in the public key database. See the publickey(4) man page for more information.
The keyserver uses the client's secret key and the server's public key to create a common key.
The keyserver encrypts the conversation key with the common key.
The transmission, which includes the encrypted time stamp and the encrypted conversation key, is then sent to the server. The transmission includes a credential and a verifier. The credential contains three components:
The client's net name
The conversation key, which is encrypted with the common key
A “window,” which is encrypted with the conversation key
The window is the difference in time that the client says should be allowed between the server's clock and the client's time stamp. If the difference between the server's clock and the time stamp is greater than the window, the server rejects the client's request. Under normal circumstances, this rejection does not happen, because the client first synchronizes with the server before starting the RPC session.
The client's verifier contains the following:
The encrypted time stamp
An encrypted verifier of the specified window, which is decremented by 1
The window verifier is needed in case somebody wants to impersonate a user. The impersonator can write a program that, instead of filling in the encrypted fields of the credential and verifier, just stuffs in random bits. The server decrypts the conversation key into some random key. The server then uses the key to try to decrypt the window and the time stamp. The result is random numbers. After a few thousand trials, however, the random window/time stamp pair is likely to pass the authentication system. The window verifier makes the process of guessing the right credential much more difficult.
When the server receives the transmission from the client, the following occurs:
The keyserver that is local to the server looks up the client's public key in the public key database.
The keyserver uses the client's public key and the server's secret key to deduce the common key. The common key is the same common key that is computed by the client. Only the server and the client can calculate the common key because the calculation requires knowing one of the secret keys.
The kernel uses the common key to decrypt the conversation key.
The kernel calls the keyserver to decrypt the client's time stamp with the decrypted conversation key.
After the server decrypts the client's time stamp, the server stores four items of information in a credential table:
The client's computer name
The window
The client's time stamp
The server stores the first three items for future use. The server stores the time stamp to protect against replays. The server accepts only time stamps that are chronologically greater than the last time stamp seen, so any replayed transactions are guaranteed to be rejected.
Implicit in these procedures are the name of the caller, who must be authenticated in some manner. The keyserver cannot use DES authentication to authenticate the caller because it would create a deadlock. To solve this problem, the keyserver stores the secret keys by user ID (UID) and grants requests only to local root processes.
The server returns a verifier to the client, which includes the following:
The index ID, which the server records in its credential cache
The client's time stamp minus 1, which is encrypted by the conversation key
The reason for subtracting 1 from the time stamp is to ensure that the time stamp is invalid. So, the time stamp cannot be reused as a client verifier.
The client receives the verifier and authenticates the server. The client knows that only the server could have sent the verifier because only the server knows what time stamp the client sent.
With every transaction after the first transaction, the client returns the index ID to the server in its second transaction and sends another encrypted time stamp. The server sends back the client's time stamp minus 1, which is encrypted by the conversation key.
A system administrator can implement policies that help secure the network. The level of security that is required differs with each site. This section provides instructions for some tasks that are associated with network security.
Become superuser or assume an equivalent role.
Verify whether the keyserv daemon is running.
# ps -ef | grep keyserv root 100 1 16 Apr 11 ? 0:00 /usr/sbin/keyserv root 2215 2211 5 09:57:28 pts/0 0:00 grep keyserv |
Start the keyserver if the process isn't running.
# /usr/sbin/keyserv |
For detailed description of NIS+ security, see System Administration Guide: Naming and Directory Services (FNS and NIS+).
Edit the /etc/nsswitch.conf file, and add the following line:
publickey: nisplus |
Initialize the NIS+ client.
# nisinit -cH hostname |
hostname is the name of a trusted NIS+ server that contains an entry in its tables for the client machine.
Add the client to the cred table by typing the following commands:
# nisaddcred local # nisaddcred des |
Verify the setup by using the keylogin command.
If you are prompted for a password, the procedure has succeeded.
The following example uses the host pluto to set up earth as an NIS+ client. You can ignore the warnings. The keylogin command is accepted, verifying that earth is correctly set up as a secure NIS+ client.
# nisinit -cH pluto NIS Server/Client setup utility. This machine is in the North.Abc.COM. directory. Setting up NIS+ client ... All done. # nisaddcred local # nisaddcred des DES principal name : unix.earth@North.Abc.COM Adding new key for unix.earth@North.Abc.Com (earth.North.Abc.COM.) Network password: xxx Press Return Warning, password differs from login password. Retype password: xxx Press Return # keylogin Password: # |
Add the user to the cred table on the root master server by typing the following command:
# nisaddcred -p unix.UID@domain-name -P username.domain-name. des |
Note that, in this case, the username.domain-name must end with a dot (.)
Verify the setup by logging in as the client and typing the keylogin command.
The following example shows how DES authorization is given to a user who is named george.
# nisaddcred -p unix.1234@North.Abc.com -P george.North.Abc.COM. des DES principal name : unix.1234@North.Abc.COM Adding new key for unix.1234@North.Abc.COM (george.North.Abc.COM.) Password: Retype password: # rlogin rootmaster -l george # keylogin Password: # |
Become superuser on the client or assume an equivalent role.
publickey: nis |
Create a new key pair by using the newkey command.
# newkey -h hostname |
hostname is the name of the client.
The following example shows how to set up earth as a secure NIS client.
# newkey -h earth Adding new key for unix.earth@North.Abc.COM New Password: Retype password: Please wait for the database to get updated... Your new key has been successfully stored away. # |
Log in to the NIS master server as superuser or assume an equivalent role.
Only system administrators, when logged in to the NIS master server, can generate a new key for a user.
Create a new key for a user.
# newkey -u username |
username is the name of the user. The system prompts for a password. You can type a generic password. The private key is stored in an encrypted form by using the generic password.
# newkey -u george Adding new key for unix.12345@Abc.North.Acme.COM New Password: Retype password: Please wait for the database to get updated... Your new key has been successfully stored away. # |
Tell the user to log in and type the chkey -p command.
This command allows the user to re-encrypt his or her private key with a password known only to the user.
earth% chkey -p Updating nis publickey database. Reencrypting key for unix.12345@Abc.North.Acme.COM Please enter the Secure-RPC password for george: Please enter the login password for george: Sending key change request to pluto... # |
The chkey command can be used to create a new key-pair for a user.
The Diffie-Hellman publickey authentication must be enabled on the network. See How to Set Up a root Key in NIS+ Credentials for Diffie-Hellman Authentication and How to Set Up a root Key by Using NIS Credentials With Diffie-Hellman Authentication.
Share the file system with Diffie-Hellman authentication.
# share -F nfs -o sec=dh /filesystem |
