Solaris 9 Installation Guide
Fall Back to the Source Boot Environment
Three procedures for falling back depend on your new boot environment activation situation:
To Fall Back Despite Successful Boot Environment Creation
In this example, the original c0t4d0s0 boot environment is reinstated as the active boot environment although it was activated successfully. The device name is first_disk.
# /usr/sbin/luactivate first_disk
# init 6
SPARC: To Fall Back From a Failed Boot Environment Activation
In this example, the new boot environment was not bootable. You must return to the OK prompt before booting from the original boot environment, c0t4d0s0, in single-user mode.
OK boot net -s
# /sbin/luactivate first_disk
Do you want to fallback to activate boot environment c0t4d0s0
(yes or no)? yes
# init 6
The original boot environment, c0t4d0s0, becomes the active boot environment.
SPARC: To Fall Back to the Original Boot Environment by Using a DVD, CD, or Net Installation Image
In this example, the new boot environment was not bootable. You cannot boot from the original boot environment and must use media or a net installation image. The device is /dev/dsk/c0t4d0s0. The original boot environment, c0t4d0s0, becomes the active boot environment.
OK boot net -s
# fsck /dev/dsk/c0t4d0s0
# mount /dev/dsk/c0t4d0s0 /mnt
# /mnt/sbin/luactivate
# umount /mnt
# init 6
