When you specify the DEFAULT_IP=BOTH or DEFAULT_IP=IP_VERSION6 variable in the inet_type file, you should have the following results:
% ifconfig -a lo0: flags=1000849 mtu 8232 index 1 inet 120.10.0.1 netmask ff000000 le0: flags=1000843 mtu 1500 index 2 inet 120.46.86.54 netmask ffffff00 broadcast 120.46.86.255 ether 8:0:20:56:a8 lo0: flags=2000849 mtu 8252 index 1 inet6 ::1/128 le0: flags=2000841 mtu 1500 index 2 ether 8:0:20:56:a8 inet6 fe80::a00:fe73:56a8/10 le0:1: flags=2080841 mtu 1500 index 2 inet6 fec0::56:a00:fe73:56a8/64 le0:2: flags=2080841 mtu 1500 index 2 inet6 2::56:a00:fe73:56a8/64 |
When you specify the DEFAULT_IP=IP_VERSION4 variable in the inet_type file, you should have the following results:
% ifconfig -a lo0: flags=849 mtu 8232 inet 120.10.0.1 netmask ff000000 le0: flags=843 mtu 1500 inet 120.46.86.54 netmask ffffff00 broadcast 120.46.86.255 ether 8:0:20:56:a8 |
