IPv6 Administration Guide
How to Control the Display Output of IPv6 Related Commands
You can control the output of the netstat and ifconfig commands. Create a file that is named inet_type in the /etc/default directory. Then, specify the value of the DEFAULT_IP variable. For more information about the inet_type, see the inet_type(4) man page.
  1. Create the /etc/default/inet_type file.
  2. Make one of the following entries, as needed.
    • To display IPv4 information only, type:
      DEFAULT_IP=IP_VERSION4
    • To display both IPv4 and IPv6 information, type:
      DEFAULT_IP=BOTH
      Or
      DEFAULT_IP=IP_VERSION6
Note –
The -4 and -6 flags in ifconfig override the value set in the inet_type file. The -f flag in netstat also overrides the value that is set in the inet_type file.
Examples—Controlling Output to Select IPv4 and IPv6 Information
