Even on a node that has been upgraded to IPv6, the use of IPv6 is dependent on the applications. An application might not use a networking API that asks the name service for IPv6 addresses. The application might use an API, such as sockets, which requires changes in the application. Also, the provider of the API, such as an implementation of the java.net class might not support IPv6 addresses. In either situation, the node only sends and receives IPv4 packets like an IPv4 node would.
The following names have become standard terminology within the Internet community:
IPv6–unaware—This application cannot handle IPv6 addresses. This application cannot communicate with nodes that do not have an IPv4 address.
IPv6–aware—This application can communicate with nodes that do not have an IPv4 address, that is, the application can handle the larger IPv6 addresses. In some situations, the address might be transparent to the application, for example, when the API hides the content and format of the actual address.
IPv6–enabled—This application can, in addition to being IPv6–aware, can use some IPv6–specific feature such as flow labels. The enabled applications can still operate over IPv4, though in a degraded mode.
IPv6–required—This application requires some IPv6–specific feature. This application cannot operate over IPv4.
