This section provides information about how to deal with general problems in the GNOME 2.0 Desktop.
Problem |
I am having a problem with the GNOME 2.0 Desktop. Where can I find more information? |
Solution |
You can find more information about the GNOME Desktop in the following places:
Problem |
How do I find which version of the GNOME Desktop is running? |
Solution |
Right click on a panel and select About GNOME. |
Problem |
When I double-click
on some file types in |
Solution |
Problem |
Solution |
Run the following command: pkill nautilus When |
Problem |
My panels crash when I select a TIF image file in the panel properties background dialog. |
Solution |
To resolve this problem you must ensure that /usr/sfw/lib precedes /usr/openwin/lib in your LD_LIBRARY_PATH. |
Problem |
How do I find out about
the |
Solution |
about The GNOME
2.0 Desktop for the Solaris Operating Environment System Administration Guide also has a chapter that describes |
Problem |
I can configure the screensaver displays in the configuration panel, but when I preview the screensaver display, or specify a blank screen, my chosen screensaver display does not appear. |
Solution |
Sun RayTM clients do not run DPMS. |
Problem |
Which operating environment
do I need to install the |
Solution |
Nautilus provides functionality similar to the Solaris Removable Media Manager. To avail of the Removable Media feature in the GNOME Desktop, the version of the operating environment must be Solaris 8 Update 1 or higher. Do not attempt to install this feature by installing a set of ad hoc patches. |
