Solaris 9 9/04 Installation Guide
Task Map: Upgrading a Boot Environment
Table 36–1 Task Map: Upgrading With Solaris Live Upgrade
Task
Description
For Instructions
Either upgrade a boot environment or install a Solaris Flash archive
  • Upgrade the inactive boot environment with an operating environment image
  • Install a Solaris Flash archive on an inactive boot environment
Activate an inactive boot environment
Makes changes effective and switches the inactive boot environment to active
Activating a Boot Environment
(optional) Switch back if a failure occurs when activating
Reactivates to the original boot environment if a failure occurs
Failure Recovery: Falling Back to the Original Boot Environment (Command-Line Interface)
