Use the Upgrade menu or luupgrade command to upgrade a boot environment. This section provides the procedure for upgrading an inactive boot environment from files that are located on the following media:
NFS server
Local file
Local tape
Local device, including DVD or CD
If the installation requires more than one CD, you must use the command-line interface procedure for upgrading. See To Upgrade an Operating System Image From Multiple CDs (Command-Line Interface).
When you upgrade a boot environment with the latest operating environment, you do not affect the active boot environment. The new files merge with the inactive boot environment critical file systems, but shareable file systems are not changed.
Rather than upgrading, if you have created a Solaris Flash archive, you could install the archive on an inactive boot environment. The new files overwrite the inactive boot environment critical file systems, but shareable file systems are not changed. See Installing Solaris Flash Archives on a Boot Environment.
You can upgrade an inactive boot environment that contains any combination of physical disk slices, Solaris Volume Manager volumes, or Veritas Volume Manager volumes. The slice that is chosen for the root (/) file system must be a single-slice concatenation that is included in a RAID–1 volume (mirror). For procedures about creating a boot environment with mirrored file systems, see To Create a Boot Environment With RAID-1 Volumes (Mirrors) (Command-Line Interface).
When upgrading and adding and removing packages or patches, Solaris Live Upgrade requires packages or patches that comply with the SVR4 advanced packaging guidelines. While Sun packages conform to these guidelines, Sun cannot guarantee the conformance of packages from third-party vendors. If a package violates these guidelines, the package can cause the package-addition software to fail or can alter the active boot environment.
For more information on adding and removing packages with Solaris Live Upgrade, see the following:
For planning information, see Managing Packages and Patches With Solaris Live Upgrade.
For information on the command and options, see the man page, luupgrade(1M).
For more information on packaging requirements, see Appendix G, Additional SVR4 Packaging Requirements (Reference).
To upgrade by using this procedure, you must use only one CD, a DVD, or a combined installation image. For an installation that requires more than one CD, you must use the procedure: To Upgrade an Operating System Image From Multiple CDs (Command-Line Interface).
From the Solaris Live Upgrade main menu, select Upgrade.
The Upgrade menu screen is displayed.
Type the new boot environment's name.
Type the path to where the Solaris installation image is located.
Installation Media Type |
Description |
Network File System |
Specify the path to the network file system where the installation image is located. |
Local file |
Specify the path to the local file system where the installation image is located. |
Local tape |
Specify the local tape device and the position on the tape where the installation image is located. |
Local device, DVD, or CD |
Specify the local device and the path to the installation image. |
If you are using DVD or one CD, type the path to that disc, as in this example:
Package Media: /cdrom/Solaris_9/s0 |
If you have a combined image on the network, type the path to the network file system as in this example:
Package Media: /net/installmachine/export/Solaris_9/os_image |
To upgrade, press F3.
When the upgrade is completed, the main menu is displayed.
To upgrade by using this procedure, you must use only one CD, a DVD, or a combined installation image. If the installation requires more than one CD, you must use the procedure: To Upgrade an Operating System Image From Multiple CDs (Command-Line Interface).
Log in as superuser.
Indicate the boot environment to upgrade and the path to the installation software by typing:
# luupgrade -u -n BE_name -s os_image_path |
Upgrades an operating system image on a boot environment
Specifies the name of the boot environment that is to be upgraded
Specifies the path name of a directory that contains an operating system image
In this example, the second_disk boot environment is upgraded.
# luupgrade -u -n second_disk \ -s /net/installmachine/export/Solaris_9/OS_image |
If the operating system image resides on two or more CDs, use this upgrade procedure.
When the installer is finished with the contents of the first CD, insert the second CD.
This step is identical to the previous step, but the -u option is replaced by the -i option. Also, choose to run the installer on the second CD with menus or with text.
This command runs the installer on the second CD with menus.
# luupgrade -i -n BE_name -s os_image_path |
This command runs the installer on the second CD with text and requires no user interaction.
# luupgrade -i -n BE_name -s os_image_path -O '-nodisplay -noconsole' |
Looks for an installation program on the specified medium and runs that program. The installer program is specified with -s.
Specifies the name of the boot environment that is to be upgraded.
Specifies the path name of a directory that contains an operating system image.
(Optional) Runs the installer on the second CD in text mode and requires no user interaction.
The boot environment is ready to be activated. See Activating a Boot Environment.
In this example, the second_disk boot environment is upgraded and the installation image is on two CDs: the Solaris Software 1 of 2 and the Solaris Software 2 of 2 CDs. The -u option determines if sufficient space for all the packages is on the CD set. The -O option with the -nodisplay and -noconsole options prevents the character user interface from displaying after the reading of the second CD. If you use these options, you are not prompted to input information. Omit these options to display the interface.
Insert the Solaris Software 1 of 2 CD and type:
# luupgrade -u -n second_disk -s /dev/cdrom/cdrom0/s0 |
Insert the Solaris Software 2 of 2 CD and type:
# luupgrade -i -n second_disk -s /dev/cdrom/cdrom0 -O '-nodisplay \ -noconsole' |
Use the luupgrade command with the -i option to install any additional CDs.
This procedure shows you how to create a profile for use with Solaris Live Upgrade. You can use this profile to upgrade an inactive boot environment by using the luupgrade command with the -j option.
For procedures to use this profile, see the following sections:
For an upgrade with a profile, see To Upgrade With a Profile by Using Solaris Live Upgrade (Command-Line Interface).
For a Solaris Flash installation with a profile, see To Install a Solaris Flash Archive With a Profile (Command-Line Interface).
Use a text editor to create a text file.
Name the file descriptively. Ensure that the name of the profile reflects how you intend to use the profile to install the Solaris software on a system. For example, you might name this profile upgrade_Solaris_9.
Add profile keywords and values to the profile.
Only the upgrade keywords in the following tables can be used in a Solaris Live Upgrade profile.
For an installation using the Install_type keyword values of upgrade or flash_install, see Table 36–2.
For an installation using the Install_type keyword value of flash_update, see Table 36–3.
Keyword |
Description |
(Required) Install_type |
Defines whether to upgrade the existing Solaris environment on a system or install a Solaris Flash archive on the system. Use the following values with this keyword:
(Required for a Solaris Flash archive) archive_location |
Retrieves a Solaris Flash archive from a designated location. For a list of values that can be used with this keyword, see archive_location Keyword. |
(Optional) cluster (adding or deleting clusters) |
Designates whether a cluster is to be added or deleted from the software group that is to be installed on the system. For a list of values that can be used with this keyword, see cluster Profile Keyword (Adding Software Groups). |
(Optional) geo |
Designates the regional locale or locales that you want to install on a system or to add when upgrading a system. For a list of values that can be used with this keyword, see geo Profile Keyword. |
(Optional) isa_bits |
Specifies whether 64-bit or 32-bit Solaris 9 packages are to be installed. For a list of values that can be used with this keyword, see isa_bits Profile Keyword. |
(Optional) local_customization |
Before you install a Solaris Flash archive on a clone system, you can create custom scripts to preserve local configurations on the clone system. The local_customization keyword designates the directory where you have stored these scripts. The value is the path to the script on the clone system. For information on predeployment and postdeployment scripts, see Creating Customization Scripts. |
(Optional) locale |
Designates the locale packages you want to install or add when upgrading. For a list of values that can be used with this keyword, see locale Profile Keyword. |
(Optional) package |
Designates whether a package is to be added to or deleted from the software group that is to be installed on the system. For a list of values that can be used with this keyword, see package Profile Keyword. |
Table 36–3 Solaris Live Upgrade Profile Keywords and Descriptions For Creating a Differential Archive
Keyword |
Description |
Defines the installation to install a Solaris Flash archive on the system. The value for a differential archive is flash_update. |
(Required) archive_location |
(Optional) forced_deployment |
Forces the installation of a Solaris Flash differential archive onto a clone system that is different than the software expects. If you use forced_deployment, all new files are deleted to bring the clone system to the expected state. If you are not certain that you want files to be deleted, use the default, which protects new files by stopping the installation. |
Before you install a Solaris Flash archive on a clone system, you can create custom scripts to preserve local configurations on the clone system. The local_customization keyword designates the directory where you have stored these scripts. The value is the path to the script on the clone system. For information about predeployment and postdeployment scripts, see Creating Customization Scripts. |
(Optional) no_content_check |
When installing a clone system with a Solaris Flash differential archive, you can use the no_content_check keyword to ignore file-by-file validation. File-by-file validation ensures that the clone system is a duplicate of the master system. Avoid using this keyword unless you are sure the clone system is a duplicate of the original master system. |
(Optional) no_master_check |
When installing a clone system with a Solaris Flash differential archive, you can use the no_master_check keyword to ignore a check of files. Clone system files are not checked. A check would ensure the clone was built from the original master system. Avoid using this keyword unless you are sure the clone system is a duplicate of the original master system. |
Save the profile in a directory on the local system.
Ensure that root owns the profile and that the permissions are set to 644.
Test the profile (optional).
For a procedure to test the profile, see To Test a Profile to Be Used by Solaris Live Upgrade.
In this example, a profile provides the upgrade parameters. This profile is to be used to upgrade an inactive boot environment with the Solaris Live Upgrade luupgrade command and the -u and -j options. This profile adds a package and a cluster. A regional locale and additional locales are also added to the profile. If you add locales to the profile, make sure that you have created a boot environment with additional disk space.
# profile keywords profile values # ---------------- ------------------- install_type upgrade package SUNWxwman add cluster SUNWCacc add geo C_Europe locale zh_TW locale zh_TW.BIG5 locale zh_TW.UTF-8 locale zh_HK.UTF-8 locale zh_HK.BIG5HK locale zh locale zh_CN.GB18030 locale zh_CN.GBK locale zh_CN.UTF-8 |
The following example of a profile is to be used by Solaris Live Upgrade to install a differential archive on a clone system. Only files that are specified by the differential archive are added, deleted, or changed. The Solaris Flash archive is retrieved from an NFS server. Because the image was built by the original master system, the clone system is not checked for a valid system image. This profile is to be used with the Solaris Live Upgrade luupgrade command and the -u and -j options.
# profile keywords profile values # ---------------- ------------------- install_type flash_update archive_location nfs installserver:/export/solaris/flasharchive/solarisarchive no_master_check
To use the luupgrade command to install the differential archive, see To Install a Solaris Flash Archive With a Profile (Command-Line Interface).
After you create a profile, use the luupgrade command to test the profile. By looking at the installation output that is generated by luupgrade, you can quickly determine if a profile works as you intended.
Test the profile.
# luupgrade -u -n BE_name -D -s os_image_path -j profile_path |
Upgrades an operating system image on a boot environment.
luupgrade command uses the selected boot environment's disk configuration to test the profile options passed with the -j option.
Specifies the path name of a directory that contains an operating system image. This directory can be on an installation medium, such as a DVD-ROM, CD-ROM, or it can be an NFS or UFS directory.
Path to a profile that is configured for an upgrade. The profile must be in a directory on the local machine.
In the following example, the profile is named upgrade_Solaris_9. The profile is successfully tested on the inactive boot environment named, u1b08.
# luupgrade -u -n u1b08 -D -s /net/installsvr/export/u1/combined.u1wos \ -j /var/tmp/flash_profile Validating the contents of the media /net/installsvr/export/u1/combined.u1wos. The media is a standard Solaris media. The media contains an operating system upgrade image. The media contains Solaris version 9. Locating upgrade profile template to use. Locating the operating system upgrade program. Checking for existence of previously scheduled Live Upgrade requests. Creating upgrade profile for BE u1b08. Determining packages to install or upgrade for BE u1b08. Simulating the operating system upgrade of the BE u1b08. The operating system upgrade simulation is complete. INFORMATION: var/sadm/system/data/upgrade_cleanup contains a log of the upgrade operation. INFORMATION: var/sadm/system/data/upgrade_cleanup contains a log of cleanup operations required. The Solaris upgrade of the boot environment u1b08 is complete. |
You can now use the profile to upgrade an inactive boot environment.
This procedure provides step-by-step instructions for upgrading an operating environment by using a profile.
If you want to install a Solaris Flash archive by using a profile, see To Install a Solaris Flash Archive With a Profile (Command-Line Interface).
If you added locales to the profile, make sure that you have created a boot environment with additional disk space.
Create a profile.
See Table 36–2 for a list of upgrade keywords that can be used in a Solaris Live Upgrade profile.
Type:
# luupgrade -u -n BE_name -s os_image_path -j profile_path |
Path to a profile. The profile must be in a directory on the local machine. For information on creating a profile, see To Create a Profile to be Used by Solaris Live Upgrade.
In this example, an archive is installed on the second_disk boot environment. The -j option is used to access the profile. The boot environment is then ready to be activated. To create a profile, see To Create a Profile to be Used by Solaris Live Upgrade.
# luupgrade -u -n second_disk \ -s /net/installmachine/export/solarisX/OS_image \ -j /var/tmp/profile |
