You can use the name_service keyword to configure the name service, the domain name, and the name server for the system. The following sample shows the general syntax for the name_service keyword.
name_service=name-service {domain_name=domain-name name_server=name-server optional-keyword=value} |
Choose only one value for name_service. Include all or none of the domain_name,name_server, or optional keywords, as needed. If no keywords are used, omit the curly braces {}.
The following sections describe the keyword syntax to configure the system to use a specific name service.
Use the following syntax to configure the system to use the NIS name service.
name_service=NIS {domain_name=domain-name name_server=hostname(ip-address)} |
Specifies the domain name
Specifies the host name of the name server
Specifies the IP address of the name server
The following example specifies a NIS server with the domain name west.example.com. The server's host name is timber, and the server IP address is 192.168.2.1.
name_service=NIS {domain_name=west.example.com name_server=timber(192.168.2.1)} |
For more information about the NIS name service, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
name_service=NIS+ {domain_name=domain-name name_server=hostname(ip-address)} |
The following example specifies a NIS+ server with the domain name west.example.com. The server's host name is timber, and the server IP address is 192.168.2.1.
name_service=NIS+ {domain_name=west.example.com name_server=timber(192.168.2.1)} |
For more information about the NIS+ name service, see System Administration Guide: Naming and Directory Services (FNS and NIS+).
Use the following syntax to configure the system to use DNS.
name_service=DNS {domain_name=domain-name name_server=ip-address,ip-address,ip-address search=domain-name,domain-name,domain-name, domain-name,domain-name,domain-name} |
Specifies the domain name.
Specifies the IP address of the DNS server. You can specify up to three IP addresses as values for the name_server keyword.
(Optional) Specifies additional domains to search for name service information. You can specify up to six domain names to search. The total length of each search entry cannot exceed 250 characters.
The following example specifies a DNS server with the domain name west.example.com. The server IP addresses are 10.0.1.10 and 10.0.1.20. example.com and east.example.com are listed as additional domains to search for name service information.
name_service=DNS {domain_name=west.example.com name_server=10.0.1.10,10.0.1.20 search=example.com,east.example.com} |
For more information about the DNS name service, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
Use the following syntax to configure the system to use LDAP.
name_service=LDAP {domain_name=domain_name profile=profile_name profile_server=ip_address proxy_dn="proxy_bind_dn" proxy_password=password} |
Specifies the domain name of the LDAP server.
Specifies the name of the LDAP profile you want to use to configure the system.
Specifies the IP address of the LDAP profile server.
(Optional) Specifies the proxy bind distinguished name. You must enclose the proxy_bind_dn value in double quotes.
(Optional) Specifies the client proxy password.
The following example specifies an LDAP server with the following configuration information.
The domain name is west.example.com.
The installation program uses the LDAP profile that is named default to configure the system.
The IP address of the LDAP server is 172.221.2.1.
The proxy bind distinguished name includes the following information.
The common name for the entry is proxyagent.
The organizational unit is profile.
The proxy domain includes the west, example, and com domain components.
The poxy password is password.
name_service=LDAP {domain_name=west.example.com profile=default profile_server=172.31.2.1 proxy_dn="cn=proxyagent,ou=profile, dc=west,dc=example,dc=com" proxy_password=password} |
For more information about how to use LDAP, see System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
