Solaris 9 9/04 Installation Guide
Upgrading, General Problems
The upgrade option is not presented even though there is a version of Solaris software that's upgradable on the system.
Cause:
Reason 1: The /var/sadm directory is a symlink or it is mounted from another file system.
Solution:
Reason 1: Move the /var/sadm directory into the root (/) or /var file system.
Cause:
Reason 2: The /var/sadm/softinfo/INST_RELEASE file is missing.
Solution:
Reason 2: Create a new INST_RELEASE file by using the following template:
OS=Solaris
VERSION=x
REV=0
x
Is the version of Solaris software on the system
Cause:
Reason 3: SUNWusr is missing from /var/sadm/softinfo.
Solution:
Solution 3: You need to do an initial installation. The Solaris software is not upgradable.
Couldn't shut down or initialize the md driver
Solution:
  • If not a mirror, comment out in the vsftab file.
  • If a mirror, break the mirror and reinstall.
The upgrade fails because the Solaris installation program cannot mount a file system.
Cause:
During an upgrade, the script attempts to mount all the file systems that are listed in the system's /etc/vfstab file on the root (/) file system that is being upgraded. If the installation script cannot mount a file system, it fails and exits.
Ensure that all file systems in the system's /etc/vfstab file can be mounted. Comment out any file systems in the /etc/vfstab file that cannot be mounted or that might cause the problem so that the Solaris suninstall program does not try to mount them during the upgrade. Any system-based file systems that contain software to be upgraded (for example, /usr) cannot be commented out.
The upgrade fails
Description:
The system does not have enough space for the upgrade.
Cause:
Check Chapter 5, System Requirements and Guidelines (Planning) for the space problem and see if you can fix it without using auto-layout to reallocate space.
Problems upgrading mirrored roots
Solution:
If you have problems upgrading when using Solaris Volume Manager mirrored roots, see “Troubleshooting Solaris Volume Manager (Tasks)” in Solaris Volume Manager Administration Guide.
