Task |
Description |
For Instructions |
Prepare to use a USB mass storage device |
Prepare to use a USB mass storage device with vold running. |
Preparing to Use a USB Mass Storage Device With vold Running |
Prepare to use a USB mass storage device without vold running. |
How to Prepare to Use USB Mass Storage Devices Without vold Running |
Display USB device information |
Use the prtconf command to display information about USB devices. | |
Format a USB mass storage device |
Format a USB mass storage device so that you can put data on it. |
How to Format a USB Mass Storage Device Without vold Running |
Mount a USB mass storage device |
Mount a USB mass storage device with vold running. |
How to Mount or Unmount a USB Mass Storage Device With vold Running |
Mount a USB mass storage device without vold running. |
How to Mount or Unmount a USB Mass Storage Device Without vold Running |
(Optional) Disable USB device drivers |
Disable USB device drivers if you do not want the USB support on your system. |
(Optional) Remove unused USB device links |
Remove unused USB device links with the devfsadm command. |
For up-to-date information on using USB mass storage devices in this Solaris release, see USB Mass Storage Devices.
Starting in the Solaris 9 release, removable mass storage devices such as USB CD-RWs, hards disks, DVDs, digital cameras, Zip, Peerless, SmartMedia, CompactFlash, ORB, and USB diskette devices are supported.
For a complete list of USB devices that are supported in the Solaris environment, see http://www.sun.com/io_technologies/USB.html.
These devices can be managed with or without volume management. For information on managing devices with volume management, see vold(1M).
USB diskette devices appear as removable media devices like other USB devices. USB diskette devices are not managed by the fd (floppy) driver. Applications that issue ioctl(2) calls intended for the fd (native floppy) driver will fail. Applications that issue only read(2) and write(2) calls will succeed. Other applications, such as SunPCI and rmformat, will also succeed.
CDE's File Manager does not fully support USB diskettes at this time. However, you can open, rename, and format diskettes that contain a UFS file system from File Manager's Removable Media Manager. You can only open diskettes that contain a PCFS file system from the Removable Media Manager. If a diskette contains either type of file system, you can successfully drag and drop files between the diskette and File Manager.
Volume management (vold) sees the USB diskette device as a SCSI removable media device. Volume management makes the device available for access under the /rmdisk directory.
For more information on how to use USB diskette devices, see Chapter 1, Managing Removable Media (Overview).
Some devices might be supported by the USB mass storage driver even though they do not identify themselves as compliant with the USB mass storage class or identify themselves incorrectly. The scsa2usb.conf file contains an attribute-override-list that lists the vendor ID, product ID, and revision for matching mass storage devices, as well as fields for overriding the default device attributes. The entries in this list are commented out by default, and can be copied and uncommented to enable support of particular devices.
If you connect a USB mass storage device to a system running this Solaris release and the system is unable to use it, you can check the /kernel/drv/scsa2usb.conf file to see if there is a matching, commented entry for this device. Follow the information given in the scsa2usb.conf file to see if a particular device can be supported by using the override information. For a listing of recommended USB mass storage devices, go to http://www.sun.com/io_technologies/USB.html.
For more information, see scsa2usb(7D).
If you are running the Solaris Common Desktop Environment (CDE), USB removable mass storage devices are managed by the Removable Media Manager component of the CDE File Manager. For more information on the CDE File Manager, see dtfile(1).
You must include the /usr/dt/man directory in your MANPATH variable to display the man pages that are listed in this section. You must also have the /usr/dt/bin directory in your path and have CDE running to use these commands, or have a DISPLAY variable set to use these commands remotely.
The following table identifies the commands that Removable Media Manager uses to manage storage devices from the CDE environment.
Command |
Man Page |
Task |
sdtmedia_format |
sdtmedia_format(1) |
Format and label a device |
sdtmedia_prop |
sdtmedia_prop(1) |
Display properties of a device |
sdtmedia_prot |
sdtmedia_prot(1) |
Change device protection |
sdtmedia_slice |
sdtmedia_slice(1) |
Create or modify slices on a device |
After the USB device is formatted, it is usually mounted under the /rmdisk/label directory. For more information on configuring removable storage devices, see rmmount.conf(4) or vold.conf(4).
The device nodes are created under the /vol/dev directory. For more information, see scsa2usb(7D).
The following procedures describe how to manage USB mass storage devices without vold running. The device nodes are created under the /dev/rdsk directory for character devices and under the /dev/dsk directory for block devices. Device links are created when the devices are hot-plugged. For more information, see scsa2usb(7D).
You can use USB mass storage devices without the volume management (vold) running. Stop vold by issuing the following command:
# /etc/init.d/volmgt stop |
Or, use the following procedure to keep vold running, but do not register the USB mass storage devices with vold.
Become superuser.
Remove volume manager registration of USB mass storage devices by commenting the following line in the /etc/vold.conf file, like this:
# use rmdisk drive /dev/rdsk/c*s2 dev_rmdisk.so rmdisk%d |
After this line is commented, restart vold.
# /etc/init.d/volmgt start |
If you comment out this line and other SCSI or ATAPI Zip, Peerless or other removable devices are in the system, vold registration for these devices would be disabled as well.
For more information, see vold.conf(4).
$ prtconf usb, instance #0 hub, instance #2 device, instance #8 interface (driver not attached) printer (driver not attached) mouse, instance #14 device, instance #9 keyboard, instance #15 mouse, instance #16 storage, instance #7 disk (driver not attached) communications, instance #10 modem (driver not attached) data (driver not attached) storage, instance #0 disk (driver not attached) storage, instance #1 disk (driver not attached) |
You can use the prtconf command's -D option to display additional driver information. This information can be used to tell which ports and devices are being driven by the USBA 1.0 framework on SPARC systems, as displayed in the following example:
$ prtconf -D . . . SUNW,Sun-Blade-1500 . . . 1 pci, instance #0 (driver name: pcisch) isa, instance #0 (driver name: ebus) . . . 2 usb, instance #0 (driver name: ohci) usb, instance #1 (driver name: ohci) . . . 3 pci, instance #0 (driver name: pci_pci) 4 usb, instance #0 (driver name: usba10_ohci) usb, instance #1 (driver name: usba10_ohci) usb, instance #0 (driver name: usba10_ehci) storage, instance #9 (driver name: usba10_scsa2usb) disk, instance #9 (driver name: usb_sd) firewire, instance #0 (driver name: hci1394) . . . |
In the output above, note the following configuration characteristics:
PCI card ports are distinguished by the number of hierarchical pci nodes in the output above their usb nodes.
PCI card ports (4) fall under two hierarchical pci nodes 1 and 3 because they are driven through both the motherboard and the PCI card. Onboard ports (2) fall under a single PCI node (1) because they are one hardware architectural layer closer to the main system bus.
The name of a driver associated with a device node indicates which framework is directing the device and the port to which the device is attached. The drivers for all USB instances of (4) begin with usba10, indicating that the USBA 1.0 framework is managing those ports and the devices attached to them. Only those ports can support USB 2.0 devices at high speed.
USB mass storage devices, as all others used by the Solaris operating system, must be formatted and contain a file system before they can be used. USB mass storage devices, including diskettes, support both PCFS and UFS file systems. Be sure the disk is formatted before putting either a PCFS or UFS file system on it.
See How to Prepare to Use USB Mass Storage Devices Without vold Running for information on disabling vold.
(Optional) Add the USB diskette device to your system.
For information on hot-plugging USB devices, see:
(Optional) Identify the diskette device.
For example:
# cd /dev/rdsk # devfsadm -C # ls -l c*0 | grep usb lrwxrwxrwx 1 root root 55 Mar 5 10:35 c2t0d0s0 -> ../../devices/pci@1f,0/usb@c,3/storage@3/disk@0,0:a,raw |
In this example, the diskette device is c2t0d0s0.
Insert a diskette into the diskette drive.
Format the diskette.
% rmformat -Flong raw-device |
For example:
% rmformat -Flong /dev/rdsk/c2t0d0s0 |
Determine the file system type and select one of the following:
Create a PCFS file system.
# mkfs -F pcfs -o nofdisk,size=size raw-device |
Specify the -size option in 512–byte blocks.
The following example shows how to create a PCFS file system on a 1.4 Mbyte diskette.
# mkfs -F pcfs -o nofdisk,size=2880 /dev/rdsk/c4t0d0s0 |
The following example shows how to create a UFS file system on a 100 Mbyte Zip drive.
# mkfs -F pcfs -o nofdisk,size=204800 /dev/rdsk/c5t0d0s0 |
This command can take several minutes to complete.
Create a UFS file system.
# newfs raw-device |
For example:
# newfs /dev/rdsk/c4t0d0s0 |
UFS file system overhead consumes a significant portion of space on a diskette, due to a diskette's limited storage capacity.
Display device aliases for all removable mass storage devices, including USB mass storage devices.
$ eject -n . . . cdrom0 -> /vol/dev/rdsk/c0t6d0/audio_cd (Generic CD device) zip0 -> /vol/dev/rdsk/c1t0d0/zip100 (USB Zip device) zip1 -> /vol/dev/rdsk/c2t0d0/fat32 (USB Zip device) rmdisk0 -> /vol/dev/rdsk/c5t0d0/unnamed_rmdisk (Peerless, HD or floppy) rmdisk1 -> /vol/dev/rdsk/c4t0d0/clik40 (Generic USB storage) |
Select one of the following to mount or unmount a USB mass storage device.
Mount a USB mass storage device by using the device aliases listed previously.
$ volrmmount -i device-alias |
This example shows how to mount a USB Zip drive (/rmdisk/zip0).
$ volrmmount -i zip0 |
Unmount a USB mass storage device.
$ volrmmount -e device-alias |
This example shows how to unmount a USB Zip drive (/rmdisk/zip0).
$ volrmmount -e zip0 |
Eject a USB device from a generic USB drive.
$ eject device-alias |
For example:
$ eject rmdisk0 |
The eject command also unmounts the device if the device is not unmounted already. The command also terminates any active applications that access the device.
Become superuser.
For example:
Mount a USB mass storage device.
# mount [ -F fstype ] block-device mount-point |
This example shows how to mount a device with a UFS file system.
# mount /dev/dsk/c1t0d0s2 /mnt |
This example shows how to mount a device with a PCFS file system.
# mount -F pcfs /dev/dsk/c1t0d0s0:c /mnt |
This example shows how to mount a CD with a read-only HSFS file system.
# mount -F hsfs -o ro /dev/dsk/c1t0d0s2 /mnt |
First, be sure no one is using the file system on the device.
For example:
# fuser -c -u /mnt # umount /mnt |
Eject the device.
# eject /dev/[r]dsk/cntndnsn |
For example:
# eject /dev/rdsk/c1t0d0s2 |
You can disable specific types of USB devices by disabling their client driver. For example, USB printers can be disabled by disabling the usbprn driver that directs them. Disabling usbprn does not affect other kinds of devices, such as USB storage devices.
Be careful that device types are disabled on both frameworks. You cannot disable device types on one framework only. The following table identifies some USB device types and their corresponding drivers.
Device Type |
Driver to Disable |
audio |
usb_ac and usb_as |
HID (usually keyboard and mouse |
hid |
storage |
scsa2usb |
printer |
usbprn |
serial |
usbser_edge |
If you disable a driver for a USB device that is still connected to the system, you will see a console message similar to the following:
usba10: WARNING: usba: no driver found for device name |
Become superuser.
Record the driver aliases that you are about to remove.
# cp /etc/driver_aliases /etc/driver_aliases.orig |
Identify the specific USB driver alias name.
For example:
# grep usbprn /etc/driver_aliases usbprn "usbif,class7.1.1" usbprn "usbif,class7.1.2" |
Remove the driver alias entry.
For example:
# update_drv -d -i '"usbif,class7.1.1"' usbprn # update_drv -d -i '"usbif,class7.1.2"' usbprn |
Reboot the system.
# init 6 |
Use this procedure if a USB device is removed while the system is powered off. It is possible that removing the USB device while the system is powered off will leave device links for devices that do not exist.
