Use this map to identify all the tasks for managing USB devices in the Solaris environment. Each task points to a series of additional tasks such as using USB devices, hot-plugging USB devices, or adding USB audio devices.
Task |
Description |
For Instructions |
Using USB devices |
USB devices must be formatted before file systems can be created and mounted. | |
Hot-plug USB devices |
Dynamically add or remove USB devices from your system. |
You can physically add or remove USB devices to and from your system. | |
Physically or logically add or remove USB devices to and from your system with the cfgadm command. | |
Add USB audio devices |
Use this map to identify tasks associated with adding USB audio devices. |
