Whenever you are required to specify a disk block number, there are two ways to enter the information:
Block number as an integer
Block number in the cylinder/head/sector format
You can specify the information as an integer that represents the logical block number. You can specify the number in any base, but the default is decimal. The maximum operator (a dollar sign, $) can also be used here to let the format utility select the appropriate value. Logical block format is used by the SunOS disk drivers in error messages.
The other way to specify a block number is by the cylinder/head/sector designation. In this method, you must specify explicitly the three logical components of the block number: the cylinder, head, and sector values. These values are still logical, but they allow you to define regions of the disk that are related to the layout of the media.
If any of the cylinder/head/sector numbers are not specified, the value is assumed to be zero. You can also use the maximum operator in place of any of the numbers and let the format utility select the appropriate value. The following are some examples of cylinder, head, and sector entries:
Enter defective block number: 34/2/3 Enter defective block number: 23/1/ Enter defective block number: 457// Enter defective block number: 12345 Enter defective block number: Oxabcd Enter defective block number: 334/$/2 Enter defective block number: 892//$ |
The format utility always prints block numbers, in both formats. Also, the help facility shows you the upper and lower bounds of the block number expected, in both formats.
