You can use the format utility to check whether a disk has the appropriate disk slices. If you determine that a disk does not contain the slices you want to use, use the format utility to re-create them and label the disk. For information on creating disk slices, see SPARC: How to Create Disk Slices and Label a Disk or x86: How to Create Disk Slices and Label a Disk.
The format utility uses the term partition instead of slice.
Become superuser or assume an equivalent role.
Invoke the format utility.
# format |
Type the number of the disk for which you want to display slice information from the list displayed on your screen.
Specify disk (enter its number):1 |
Select the partition menu.
format> partition |
Display the slice information for the current disk drive.
partition> print |
Exit the format utility.
partition> q format> q # |
Verify the displayed slice information by identifying specific slice tags and slices.
If the screen output shows that no slice sizes are assigned, the disk probably does not have slices.
The following example displays slice information for disk with a VTOC label.
# format Searching for disks...done Specify disk (enter its number):1 Selecting c0t0d0 format> partition partition> print Current partition table (original): Total disk cylinders available: 8892 + 2 (reserved cylinders) Part Tag Flag Cylinders Size Blocks 0 root wm 1110 - 4687 1.61GB (0/3578/0) 3381210 1 swap wu 0 - 1109 512.00MB (0/1110/0) 1048950 2 backup wm 0 - 8891 4.01GB (0/8892/0) 8402940 3 unassigned wm 0 0 (0/0/0) 0 4 unassigned wm 0 0 (0/0/0) 0 5 unassigned wm 0 0 (0/0/0) 0 6 unassigned wm 0 0 (0/0/0) 0 7 home wm 4688 - 8891 1.89GB (0/4204/0) 3972780 partition> q format> q # |
For a detailed description of the slice information in these examples, see Chapter 10, Managing Disks (Overview).
The following example shows the slice information on a disk with an EFI label.
# format Searching for disks...done Specify disk (enter its number): 9 selecting c4t1d0 [disk formatted] format> partition partition> print Current partition table (original): partition> q format> q Part Tag Flag First Sector Size Last Sector 0 root wm 34 300.00GB 629145633 1 usr wm 629145634 300.00GB 1258291233 2 unassigned wm 0 0 0 3 unassigned wm 0 0 0 4 unassigned wm 0 0 0 5 unassigned wm 0 0 0 6 usr wm 1258291234 628.77GB 2576924637 8 reserved wm 2576924638 8.00MB 2576941021 |
