The labeling of a disk is usually done during system installation or when you are creating new disk slices. You might need to relabel a disk if the disk label becomes corrupted (for example, from a power failure).
The format utility attempts to automatically configure any unlabeled SCSI disk. If the format utility is able to automatically configure an unlabeled disk, it displays a message like the following:
c0t0d1: configured with capacity of 4.00GB |
For information on labeling multiple disks with the same disk label, see Label Multiple Disks by Using the prtvtoc and fmthard Commands.
You can use the following procedure to label at disk with a VTOC label or a disk greater than 1 terabyte with an EFI label. If you want to put an EFI label on disk smaller than 1 terabyte, see Example 11–6.
Become superuser or assume an equivalent role.
Invoke the format utility.
# format |
Type the number of the disk that you want to label from the list displayed on your screen.
Specify disk (enter its number):1 |
Select one of the following.
If the disk is unlabeled and was successfully configured, go to step 5 to label the disk.
The format utility will ask if you want to label the disk.
If the disk is labeled and you want to change the disk type, or if the format utility was not able to automatically configure the disk, follow steps 6-7 to set the disk type and label the disk.
Label the disk by typing y at the Label it now? prompt.
Disk not labeled. Label it now? y |
The disk is now labeled. Go to step 10 to exit the format utility.
Enter type at the format> prompt.
format> type |
The Available Drive Types menu is displayed.
Select a disk type from the list of possible disk types.
Specify disk type (enter its number)[12]: 12 |
Or, select 0 to automatically configure a SCSI-2 disk. For more information, see How to Automatically Configure a SCSI Drive.
Label the disk. If the disk is not labeled, the following message is displayed.
Otherwise, you are prompted with this message:
Ready to label disk, continue? y |
Verify the disk label.
format> verify |
Exit the format utility.
partition> q format> q # |
The following example shows how to automatically configure and label a 1.05-Gbyte disk.
# format c1t0d0: configured with capacity of 1002.09MB AVAILABLE DISK SELECTIONS: 0. c0t3d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72> /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@1,0 1. c1t0d0 <SUN1.05 cyl 2036 alt 2 hd 14 sec 72> /iommu@f,e0000000/sbus@f,e0001000/espdma@f,400000/esp@f,800000/sd@1,0 Specify disk (enter its number): 1 Disk not labeled. Label it now? yes format> verify # |
The following example shows how to use the format -e command to label a disk less than 1 terabyte with an EFI label. Remember to verify that your layered software products will continue to work on systems with EFI-labeled disks. For general information on EFI label restrictions, see Restrictions of the EFI Disk Label.
# format -e Searching for disks...done AVAILABLE DISK SELECTIONS: 1. c1t0d0 <SUNW18g cyl 7506 alt 2 hd 19 sec 248> /sbus@2,0/QLGC,isp@2,10000/sd@0,0 2. c1t1d0 <SUNW18g cyl 7506 alt 2 hd 19 sec 248> /sbus@2,0/QLGC,isp@2,10000/sd@1,0 3. c1t8d0 <SUNW18g cyl 7506 alt 2 hd 19 sec 248> /sbus@2,0/QLGC,isp@2,10000/sd@8,0 4. c1t9d0 <SUNW18g cyl 7506 alt 2 hd 19 sec 248> /sbus@2,0/QLGC,isp@2,10000/sd@9,0 Specify disk (enter its number): 4 selecting c1t9d0 [disk formatted] format> label [0] SMI Label [1] EFI Label Specify Label type[0]: 1 Ready to label disk, continue? yes format> quit |
Examine disk label information by using the prtvtoc command. For a detailed description of the disk label and the information that is displayed by the prtvtoc command, see Chapter 10, Managing Disks (Overview).
Display the disk label information.
# prtvtoc /dev/rdsk/device-name |
device-name is the raw disk device you want to examine.
The following example shows the disk label information for disk with a VTOC label.
# prtvtoc /dev/rdsk/c0t0d0s0 * /dev/rdsk/c0t0d0s0 partition map * * Dimensions: * 512 bytes/sector * 63 sectors/track * 15 tracks/cylinder * 945 sectors/cylinder * 8894 cylinders * 8892 accessible cylinders * * Flags: * 1: unmountable * 10: read-only * * First Sector Last * Partition Tag Flags Sector Count Sector Mount Directory 0 2 00 1048950 3381210 4430159 / 1 3 01 0 1048950 1048949 2 5 00 0 8402940 8402939 7 8 00 4430160 3972780 8402939 /export/home |
The following example shows the disk label information for disk with an EFI label.
# prtvtoc /dev/rdsk/c3t1d0s0 * /dev/rdsk/c3t1d0s0 partition map * * Dimensions: * 512 bytes/sector * 2479267840 sectors * 2479267773 accessible sectors * * Flags: * 1: unmountable * 10: read-only * * First Sector Last * Partition Tag Flags Sector Count Sector Mount Directory 0 2 00 34 262144 262177 1 3 01 262178 262144 524321 6 4 00 524322 2478727100 2479251421 8 11 00 2479251422 16384 2479267805 |
