Become superuser or assume an equivalent role.
Invoke the format utility.
# format |
Type the number of the disk that you want to format from the list displayed on your screen.
Specify disk (enter its number): 0 |
Do not select the system disk. If you format your system disk, you delete the operating system and any data on this disk.
To begin formatting the disk, type format at the format> prompt. Confirm the command by typing y.
format> format Ready to format. Formatting cannot be interrupted and takes 23 minutes (estimated). Continue? yes |
Verify that the disk format is successful by noting the following messages.
Beginning format. The current time Tue ABC xx xx:xx:xx xxxx Formatting... done Verifying media... pass 0 - pattern = 0xc6dec6de 2035/12/18 pass 1 - pattern = 0x6db6db6d 2035/12/18 Total of 0 defective blocks repaired. |
The following example shows how to format the disk c0t3d0.
# format Searching for disks...done AVAILABLE DISK SELECTIONS: 0. c0t0d0 <SUNW18G cyl 7506 alt 2 hd 19 sec 248 /pci@1f,0/pci@1,1/scsi@2/sd@0,0 1. c0t1d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@1,0 2. c0t2d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@2,0 3. c0t3d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@3,0 4. c0t4d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@4,0 5. c0t5d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@5,0 6. c0t6d0 <FUJITSU MAN3367M SUN36G 1804 43d671f> /pci@1f,0/pci@1,1/scsi@2/sd@6,0 Specify disk (enter its number): 6 selecting c0t6d0 [disk formatted] format> format Ready to format. Formatting cannot be interrupted and takes 332 minutes (estimated). Continue? y Beginning format. The current time is Wed Jan 7 16:16:05 2004 Formatting... 99% complete (00:00:21 remaining) done Verifying media... pass 0 - pattern = 0xc6dec6de 71132922 pass 1 - pattern = 0x6db6db6d 71132922 Total of 0 defective blocks repaired. format> quit |
