System Administration Guide: Devices and File Systems
Creating an Audio CD
You can use the cdrw command to create audio CDs from individual audio tracks or from .au and .wav files.
The supported audio formats are:
Format
Description
sun
Sun .au files with data in Red Book CDDA format
wav
RIFF (.wav) files with data in Red Book CDDA format
cda
.cda files with raw CD audio data, which is 16–bit PCM stereo at 44.1 kHz sample rate in little-endian byte order)
aur
.aur files with raw CD data in big-endian byte order
If no audio format is specified, the cdrw command tries to determine the audio file format based on the file extension. The case of the characters in the extension is ignored.
