System Administration Guide: Devices and File Systems
ProcedureHow to Create an Audio CD
This procedure describes how to copy audio files onto a CD.
Steps
  1. Insert a blank CD into the CD-RW device.
  2. Change to the directory that contains the audio files.
    $ cd /myaudiodir
  3. Copy the audio files onto the CD.
    $ cdrw -a track1.wav track2.wav track3.wav
    The -a option creates an audio CD.
Example 4–2 Creating an Audio CD
The following example shows how to create an audio CD.
$ cdrw -a bark.wav chirp.au meow.wav
Initializing device...done.
Writing track 1...done.
done.
Writing track 2...done.
Writing track 3...done.
done.
Finalizing (Can take several minutes)...done.
The following example shows how to create a multisession audio CD. The CD is ejected after the first session is written. Re-insert the CD before the next writing session.
$ cdrw -aO groucho.wav chico.au harpo.wav
done.
done.
<Re-insert CD>
$ cdrw -a zeppo.au
done.
