DBMS エラーおよび記録された警告用の事前設定アクションは、次に一覧表示されています。
表 1 DBMS エラー用の事前設定アクション
エラー番号 |
アクション |
接続状態 |
新規状態 |
メッセージ |
18 |
NONE |
co |
di |
Max. number of DBMS sessions exceeded |
20 |
NONE |
co |
di |
Max. number of DBMS processes exceeded |
28 |
NONE |
on |
di |
Session killed by DBA, will reconnect |
50 |
SWITCH |
di |
O/S error occurred while obtaining an enqueue. See o/s error. |
51 |
NONE |
di |
timeout occurred while waiting for resource |
55 |
NONE |
maximum number of DML locks in DBMS exceeded |
62 |
STOP |
di |
Need to set DML_LOCKS in init.ora file to value other than 0 |
107 |
RESTART |
di |
failed to connect to ORACLE listener process |
257 |
NONE |
di |
archiver error. Connect internal only, until freed. |
290 |
SWITCH |
di |
Operating system archival error occurred. Check alert log. |
447 |
SWITCH |
di |
fatal error in background process |
448 |
RESTART |
di |
normal completion of background process |
449 |
RESTART |
di |
background process `%s' unexpectedly terminated with error %s |
470 |
SWITCH |
di |
Oracle background process died |
471 |
SWITCH |
di |
472 |
SWITCH |
di |
473 |
SWITCH |
di |
474 |
RESTART |
di |
SMON died, warm start required |
475 |
SWITCH |
di |
476 |
SWITCH |
di |
477 |
SWITCH |
di |
480 |
RESTART |
di |
LCK* process terminated with error |
481 |
RESTART |
di |
LMON process terminated with error |
482 |
RESTART |
di |
LMD* process terminated with error |
602 |
SWITCH |
di |
internal programming exception |
604 |
NONE |
on |
di |
Recursive error |
705 |
RESTART |
di |
inconsistent state during start up |
942 |
NONE |
on |
Warning - V$SYSSTAT not accessible - check grant on V_$SYSSTAT |
1001 |
NONE |
on |
di |
Lost connection to database |
1002 |
NONE |
on |
Internal error in HA-DBMS Oracle |
1003 |
NONE |
on |
di |
Resetting database connection |
1012 |
NONE |
on |
di |
Not logged on |
1012 |
RESTART |
di |
co |
Not logged on |
1014 |
NONE |
ORACLE shutdown in progress |
1017 |
STOP |
Please correct login information in HA-DBMS Oracle database configuration |
1031 |
NONE |
on |
Insufficient privileges to perform DBMS operations - check Oracle user privileges |
1033 |
NONE |
co |
co |
Oracle is in the shutdown or initialization process |
1033 |
NONE |
di |
1034 |
RESTART |
co |
co |
Oracle is not available |
1034 |
RESTART |
di |
co |
1034 |
NONE |
on |
di |
1035 |
RESTART |
co |
co |
Access restricted - restarting database to reset |
1041 |
NONE |
on |
di |
1041 |
NONE |
di |
co |
1045 |
NONE |
co |
Fault monitor user lacks CREATE SESSION privilege logon denied. |
1046 |
RESTART |
di |
cannot acquire space to extend context area |
1050 |
RESTART |
di |
cannot acquire space to open context area |
1053 |
SWITCH |
user storage address cannot be read or written |
1054 |
SWITCH |
1075 |
NONE |
co |
on |
Already logged on |
1089 |
NONE |
on |
di |
immediate shutdown in progresss |
1089 |
NONE |
Investigate! Could be hanging! |
1090 |
NONE |
di |
shutdown in progress - connection is not permitted |
1092 |
NONE |
di |
ORACLE instance terminated. Disconnection forced |
1513 |
SWITCH |
invalid current time returned by operating system |
1542 |
NONE |
on |
table space is off-line - please correct! |
1552 |
NONE |
on |
rollback segment is off-line - please correct! |
1950 |
NONE |
on |
2701 |
STOP |
HA-DBMS Oracle error - ORACLE_HOME did not get set! |
2703 |
RESTART |
di |
2704 |
RESTART |
di |
2709 |
RESTART |
di |
2710 |
RESTART |
di |
2719 |
RESTART |
di |
2721 |
RESTART |
2726 |
STOP |
Could not locate ORACLE executables - check ORACLE_HOME setting |
2735 |
RESTART |
osnfpm: cannot create shared memory segment |
2811 |
SWITCH |
Unable to attach shared memory segment |
2839 |
SWITCH |
Sync of blocks to disk failed. |
2840 |
SWITCH |
2846 |
SWITCH |
2847 |
SWITCH |
2849 |
SWITCH |
2842 |
RESTART |
Client unable to fork a server - Out of memory |
3113 |
RESTART |
co |
di |
lost connection |
3113 |
NONE |
on |
di |
lost connection |
3113 |
NONE |
di |
di |
lost connection |
3114 |
NONE |
co |
Not connected? |
4030 |
RESTART |
4032 |
RESTART |
4100 |
RESTART |
communication area cannot be allocated insufficient memory |
6108 |
STOP |
co |
Can't connect to remote database - make sure SQL*Net server is up |
6114 |
STOP |
co |
Can't connect to remote database - check SQL*Net configuration |
7205 |
SWITCH |
di |
7206 |
SWITCH |
di |
7208 |
SWITCH |
di |
7210 |
SWITCH |
di |
7211 |
SWITCH |
di |
7212 |
SWITCH |
di |
7213 |
SWITCH |
di |
7214 |
SWITCH |
di |
7215 |
SWITCH |
di |
7216 |
SWITCH |
di |
7218 |
SWITCH |
di |
7219 |
RESTART |
slspool: unable to allocate spooler argument buffer. |
7223 |
RESTART |
slspool: fork error, unable to spawn spool process. - Resource limit reached |
7224 |
SWITCH |
7229 |
SWITCH |
7232 |
SWITCH |
7234 |
SWITCH |
7238 |
SWITCH |
slemcl: close error. |
7250 |
RESTART |
7251 |
RESTART |
7252 |
RESTART |
7253 |
RESTART |
7258 |
RESTART |
7259 |
RESTART |
7263 |
SWITCH |
7269 |
SWITCH |
7279 |
SWITCH |
7280 |
RESTART |
7296 |
SWITCH |
7297 |
SWITCH |
7306 |
RESTART |
7310 |
SWITCH |
7315 |
SWITCH |
7321 |
SWITCH |
7322 |
SWITCH |
7324 |
RESTART |
7325 |
RESTART |
7351 |
SWITCH |
7361 |
RESTART |
7404 |
SWITCH |
7414 |
RESTART |
7415 |
RESTART |
7417 |
SWITCH |
7418 |
SWITCH |
7419 |
SWITCH |
7430 |
SWITCH |
7455 |
SWITCH |
7456 |
SWITCH |
7466 |
SWITCH |
7470 |
SWITCH |
7475 |
SWITCH |
7476 |
SWITCH |
7477 |
SWITCH |
7478 |
SWITCH |
7479 |
SWITCH |
7481 |
SWITCH |
9706 |
SWITCH |
9716 |
SWITCH |
9718 |
RESTART |
9740 |
SWITCH |
9748 |
SWITCH |
9747 |
RESTART |
9749 |
RESTART |
9751 |
RESTART |
9755 |
RESTART |
9757 |
RESTART |
9756 |
SWITCH |
9758 |
SWITCH |
9761 |
RESTART |
9765 |
RESTART |
9779 |
RESTART |
9829 |
RESTART |
9831 |
SWITCH |
9834 |
SWITCH |
9836 |
SWITCH |
9838 |
SWITCH |
9837 |
RESTART |
9844 |
RESTART |
9845 |
RESTART |
9846 |
RESTART |
9847 |
RESTART |
9853 |
SWITCH |
9854 |
SWITCH |
9856 |
RESTART |
9874 |
SWITCH |
9876 |
SWITCH |
9877 |
RESTART |
9878 |
RESTART |
9879 |
RESTART |
9885 |
RESTART |
9888 |
RESTART |
9894 |
RESTART |
9909 |
RESTART |
9912 |
RESTART |
9913 |
RESTART |
9919 |
SWITCH |
9943 |
RESTART |
9947 |
RESTART |
9948 |
SWITCH |
9949 |
SWITCH |
9950 |
SWITCH |
12505 |
STOP |
TNS:listener could not resolve SID given in connect descriptor.Check listener configuration file. |
12541 |
STOP |
TNS:no listener. Please verify connect_string property, listener and TNSconfiguration. |
12545 |
SWITCH |
Please check HA-Oracle parameters. Connect failed because target host or object does not exist |
27100 |
STOP |
Shared memory realm already exists |
98765 |
STOP |
Database role queried from database does not match the Sun Cluster resource's dataguard role configuration. |
99999 |
RESTART |
di |
Monitor detected death of Oracle background processes. |
表 2 記録された警告用の事前設定アクション
警告文字列 |
アクション |
接続状態 |
新規状態 |
メッセージ |
ORA-07265 |
SWITCH |
di |
Semaphore access problem |
found dead multi-threaded server |
NONE |
Warning: Multi-threaded Oracle server process died (restarted automatically) |
found dead dispatcher |
NONE |
Warning: Oracle dispatcher process died (restarted automatically) |
