Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
delete-system-property [--help] [--target target_name ] [property_name]
The delete-system-property subcommand deletes a system property of a domain, configuration, cluster, or server instance. Make sure that the system property is not referenced elsewhere in the configuration before deleting it.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
Do not specify this option. This option is retained for compatibility with other releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and the option is silently ignored.
This example deletes the system property named http-listener-port.
asadmin> delete-system-property http-listener-port Command delete-system-property executed successfully. |
