Name | Synopsis | Description | Options | Examples | Exit Status | See Also
list-system-properties [--help] [--target target]
The list-system-properties subcommand lists the system properties of a domain.
This subcommand is supported in remote mode only.
Displays the help text for the subcommand.
Do not specify this option. This option is retained for compatibility with other releases. If you specify this option, a syntax error does not occur. Instead, the subcommand runs successfully and the option is silently ignored.
This example lists the system properties on localhost.
asadmin> list-system-properties http-listener-port=1088 Command list-system-properties executed successfully. |
