Go to main content
oracle home
Sun Network 10GbE Switch 72p Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Network 10GbE Switch 72p Documentation ...
Updated: November 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Late-Breaking Information
Switch Documentation Reading Order
New Features
IPv6 Switching and Routing
PVRST+ Protocol
Exclusive VLAN
Data Center Bridging
Internet Group Management Protocol
PIM
Q-in-Q Tunneling
Server Load Balancer Layer 3
Uplink Port Trailing
VRRPv3
Oracle ILOM 3.0 Features
Enhancements
Upgrading the Switch Firmware
Back Up the Current Configuration Before Upgrading
Download the Switch Firmware Package
Install the Switch Updates
Configuring the Switch
Configure 1Gbps Mode on SFP+ Interfaces
Fine Tune the VLAN Setup
Managing SEFOS Configurations
Include the SEFOS Configuration in Backups
Restore the Configuration
Configuring TACACS+
TACACS+ Properties
Configure TACACS+ Settings
Known Issues
Manually Deleting Static Routes Does Not Affect the Corresponding SLB Entry (7123134)
PIMv6-SSM Mode is Not Supported in This Release (7114280)
Firmware Upgrade With the Web UI is Incomplete (7022295)
Changing the Default Value for default-vlan-id Could Result in VLAN Misconfiguration (7015004)
Some of the IGMP Conformance Results Do Not Match Expectations (7006297 and 6997415)
QoS - set algo-type tailDrop queue-drop-algo Does Not Work (6991230)
Packets Might Be Dropped When Using Q-in-Q Interop in Certain Configurations (6989048)
The no default-metric [,short(1-16)>] Command Does Not Work as Documented (6987482)
Using vlan 1 as Shown in Various Examples in the Documentation Generates Error Codes (6968484)
When Multiple Configuration Scripts Are Run in Parallel, SEFOS Can Crash (6936742)
The switch Command Line Option Is Unsupported
vrrp_v3: Role is incorrect for vlan with no premempt configuration after save/reboot (19547263)
SSL V3.0 POODLE DISABLE SSL V3 (19842635)
Re-configure IP address after a "no ip address", previous config re-appears (18794861)
Language:
English
November 2016
Provides late-breaking information about the switch.
Feedback
New Features
PVRST+ Protocol
Exclusive VLAN
PIM
Q-in-Q Tunneling
VRRPv3
Enhancements
Configuring TACACS+
TACACS+ Properties
Known Issues
