Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System Uplink Port Trailing Administration Guide
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Sun Ethernet Fabric Operating System Uplink Port Trailing Protocol
Uplink Port Trailing Topology Example
Configure NEM24p-0
Configure NEM24p-1
Configure the ToR72
Verify the Configurations
Configure the Host
Verify the Uplink Port Trailing Feature
Configure the Host
  1. Configure the Host-1 interface to accept VLAN 300 and 301 traffic.
    [Host-1]# ifconfig -a
    eth4.300  Link encap:Ethernet  HWaddr 90:E2:BA:79:83:94
              inet addr:192.168.30.20  Bcast:192.168.30.255  Mask:255.255.255.0
              inet6 addr: fe80::92e2:baff:fe79:8394/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:374 errors:0 dropped:0 overruns:0 frame:0
              TX packets:377 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:0
              RX bytes:30622 (29.9 KiB)  TX bytes:35858 (35.0 KiB)
    eth4.301  Link encap:Ethernet  HWaddr 90:E2:BA:79:83:94
              inet addr:192.168.31.20  Bcast:192.168.31.255  Mask:255.255.255.0
              RX packets:2 errors:0 dropped:0 overruns:0 frame:0
              TX packets:6 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:92 (92.0 b)  TX bytes:468 (468.0 b)
  2. Configure a bond interface using two interfaces connecting to the NEM24p-0 and NEM24p-1 such that the bond interface accepts both VLAN 300 and 301 traffic.
    [Host-2]# cat /proc/net/bonding/bond0
    Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
    Bonding Mode: fault-tolerance (active-backup)
    Primary Slave: eth7 (primary_reselect always)
    Currently Active Slave: eth7
    MII Status: up
    MII Polling Interval (ms): 100
    Up Delay (ms): 0
    Down Delay (ms): 0
    Slave Interface: eth6
    MII Status: up
    Speed: 10000 Mbps
    Duplex: full
    Link Failure Count: 5
    Permanent HW addr: 00:1b:21:66:48:ec
    Slave queue ID: 0
    Slave Interface: eth7
    MII Status: up
    Speed: 10000 Mbps
    Duplex: full
    Link Failure Count: 11
    Permanent HW addr: 00:1b:21:66:48:ed
    Slave queue ID: 0
    [Host-2]# ifconfig -a
    bond0.300 Link encap:Ethernet  HWaddr 00:1B:21:66:48:EC
              inet addr:192.168.30.50  Bcast:192.168.30.255  Mask:255.255.255.0
              inet6 addr: fe80::21b:21ff:fe66:48ec/64 Scope:Link
              TX packets:536 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:30622 (29.9 KiB)  TX bytes:45960 (44.8 KiB)
    bond0.301 Link encap:Ethernet  HWaddr 00:1B:21:66:48:EC
              inet addr:192.168.31.50  Bcast:192.168.31.255  Mask:255.255.255.0
              RX packets:0 errors:0 dropped:0 overruns:0 frame:0
              TX packets:39 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:0 (0.0 b)  TX bytes:2646 (2.5 KiB)
    NEM24p-1 SEFOS# sh uplink-trailing group 20 detail
    Uplink Trailing Group 20
    Description:     Uplink-trailing between NEM24p-1 & ToR72p-1
            Admin Status:            Enabled
            Status:                  Up
    Link State Change: Up   1       Down    0
    Port             Type   Status
    Ex0/1        uplink      Up
    Ex0/18       downlink    Up
