Skip Navigation Links
Exit Print View
man pages section 1: User Commands     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
Preface
Introduction
User Commands
acctcom(1)
adb(1)
addbib(1)
admin(1)
alias(1)
allocate(1)
amt(1)
appcert(1)
apptrace(1)
apropos(1)
ar(1)
arch(1)
as(1)
asa(1)
at(1)
atq(1)
atrm(1)
audioconvert(1)
audioctl(1)
audioplay(1)
audiorecord(1)
audiotest(1)
auths(1)
auto_ef(1)
awk(1)
banner(1)
basename(1)
basename(1B)
batch(1)
bc(1)
bdiff(1)
bfs(1)
bg(1)
biff(1B)
break(1)
builtin(1)
cal(1)
calendar(1)
cancel(1)
case(1)
cat(1)
cd(1)
cdc(1)
cdrw(1)
chdir(1)
checkeq(1)
checknr(1)
chgrp(1)
chkey(1)
chmod(1)
chown(1)
chown(1B)
ckdate(1)
ckgid(1)
ckint(1)
ckitem(1)
ckkeywd(1)
ckpath(1)
ckrange(1)
ckstr(1)
cksum(1)
cktime(1)
ckuid(1)
ckyorn(1)
clear(1)
cmp(1)
col(1)
comb(1)
comm(1)
command(1)
compress(1)
continue(1)
cp(1)
cpio(1)
cpp(1)
cputrack(1)
crle(1)
crontab(1)
crypt(1)
csh(1)
csplit(1)
ct(1C)
ctags(1)
ctrun(1)
ctstat(1)
ctwatch(1)
cu(1C)
cut(1)
date(1)
dc(1)
deallocate(1)
decrypt(1)
delta(1)
deroff(1)
des(1)
df(1B)
dhcpinfo(1)
diff(1)
diff3(1)
diffmk(1)
digest(1)
digestp(1)
dircmp(1)
dirname(1)
dirs(1)
dis(1)
disable(1)
disown(1)
dispgid(1)
dispuid(1)
dos2unix(1)
download(1)
dpost(1)
du(1)
du(1B)
dump(1)
dumpcs(1)
dumpkeys(1)
echo(1)
echo(1B)
ed(1)
edit(1)
egrep(1)
eject(1)
elfdump(1)
elfedit(1)
elfsign(1)
elfwrap(1)
enable(1)
encrypt(1)
enhance(1)
env(1)
eqn(1)
errange(1)
errdate(1)
errgid(1)
errint(1)
erritem(1)
error(1)
errpath(1)
errstr(1)
errtime(1)
erruid(1)
erryorn(1)
eval(1)
ex(1)
exec(1)
exit(1)
expand(1)
export(1)
exportfs(1B)
expr(1)
expr(1B)
exstr(1)
factor(1)
false(1)
fastboot(1B)
fasthalt(1B)
fc(1)
fdformat(1)
fg(1)
fgrep(1)
file(1)
file(1B)
filebench(1)
filep(1)
filesync(1)
filofaxp(1)
find(1)
finger(1)
fmt(1)
fmtmsg(1)
fold(1)
for(1)
foreach(1)
franklinp(1)
from(1B)
ftp(1)
ftpcount(1)
ftpwho(1)
function(1)
gcore(1)
gencat(1)
geniconvtbl(1)
genmsg(1)
get(1)
getconf(1)
getfacl(1)
getlabel(1)
getopt(1)
getoptcvt(1)
getopts(1)
gettext(1)
gettxt(1)
getzonepath(1)
glob(1)
goto(1)
gprof(1)
grep(1)
groups(1)
groups(1B)
grpck(1B)
hash(1)
hashcheck(1)
hashmake(1)
hashstat(1)
head(1)
help(1)
helpdate(1)
helpgid(1)
helpint(1)
helpitem(1)
helppath(1)
helprange(1)
helpstr(1)
helptime(1)
helpuid(1)
helpyorn(1)
hist(1)
history(1)
hostid(1)
hostname(1)
i286(1)
i386(1)
i486(1)
i860(1)
iAPX286(1)
iconv(1)
idnconv(1)
if(1)
indxbib(1)
install(1B)
ipcrm(1)
ipcs(1)
isainfo(1)
isalist(1)
jobs(1)
join(1)
jsh(1)
kbd(1)
kdestroy(1)
keylogin(1)
keylogout(1)
kill(1)
kinit(1)
klist(1)
kmdb(1)
kmfcfg(1)
kpasswd(1)
krb5-config(1)
ksh(1)
ksh93(1)
ktutil(1)
lari(1)
last(1)
lastcomm(1)
ld(1)
ldap(1)
ldapadd(1)
ldapdelete(1)
ldaplist(1)
ldapmodify(1)
ldapmodrdn(1)
ldapsearch(1)
ldd(1)
ld.so.1(1)
let(1)
lex(1)
lgrpinfo(1)
limit(1)
line(1)
list_devices(1)
listusers(1)
llc2_autoconfig(1)
llc2_config(1)
llc2_stats(1)
ln(1)
ln(1B)
loadkeys(1)
locale(1)
localedef(1)
logger(1)
logger(1B)
login(1)
logname(1)
logout(1)
look(1)
lookbib(1)
lorder(1)
lp(1)
lpc(1B)
lpq(1B)
lpr(1B)
lprm(1B)
lpstat(1)
lptest(1B)
ls(1)
ls(1B)
m4(1)
mac(1)
mach(1)
machid(1)
madv.so.1(1)
mail(1)
Mail(1B)
mail(1B)
mailcompat(1)
mailp(1)
mailq(1)
mailstats(1)
mailx(1)
make(1S)
makekey(1)
man(1)
mconnect(1)
mcs(1)
mdb(1)
mesg(1)
mkdir(1)
mkmsgs(1)
mkstr(1B)
mktemp(1)
moe(1)
more(1)
mp(1)
mpss.so.1(1)
msgcc(1)
msgcpp(1)
msgcvt(1)
msgfmt(1)
msggen(1)
msgget(1)
mt(1)
mv(1)
nawk(1)
nc(1)
nca(1)
ncab2clf(1)
ncakmod(1)
neqn(1)
newform(1)
newgrp(1)
news(1)
newsp(1)
newtask(1)
nice(1)
nl(1)
nm(1)
nohup(1)
notify(1)
nroff(1)
od(1)
on(1)
onintr(1)
optisa(1)
pack(1)
page(1)
pagesize(1)
pargs(1)
passwd(1)
paste(1)
patch(1)
pathchk(1)
pax(1)
pcat(1)
pcred(1)
pdp11(1)
perl(1)
pfcsh(1)
pfexec(1)
pfiles(1)
pfksh(1)
pflags(1)
pfsh(1)
pg(1)
pgrep(1)
pkcs11_inspect(1)
pkginfo(1)
pkgmk(1)
pkgparam(1)
pkgproto(1)
pkgtrans(1)
pkill(1)
pklogin_finder(1)
pktool(1)
plabel(1)
pldd(1)
plgrp(1)
plimit(1)
pmadvise(1)
pmap(1)
popd(1)
postdaisy(1)
postdmd(1)
postio(1)
postmd(1)
postplot(1)
postprint(1)
postreverse(1)
posttek(1)
ppgsz(1)
ppriv(1)
pr(1)
praliases(1)
prctl(1)
preap(1)
prex(1)
print(1)
printenv(1B)
printf(1)
priocntl(1)
proc(1)
prof(1)
profiles(1)
projects(1)
prs(1)
prt(1)
prun(1)
ps(1)
ps(1B)
psig(1)
pstack(1)
pstop(1)
ptime(1)
ptree(1)
pushd(1)
pvs(1)
pwait(1)
pwd(1)
pwdx(1)
ranlib(1)
rcapstat(1)
rcp(1)
rdist(1)
read(1)
readonly(1)
red(1)
refer(1)
regcmp(1)
rehash(1)
remote_shell(1)
remsh(1)
renice(1)
repeat(1)
reset(1B)
return(1)
rev(1)
rksh(1)
rksh93(1)
rlogin(1)
rm(1)
rmail(1)
rmdel(1)
rmdir(1)
rmformat(1)
rmmount(1)
rmumount(1)
roffbib(1)
roles(1)
rpcgen(1)
rpm2cpio(1)
rsh(1)
runat(1)
rup(1)
rup(1C)
ruptime(1)
rusage(1B)
rusers(1)
rwho(1)
sact(1)
sar(1)
sccs(1)
sccs-admin(1)
sccs-cdc(1)
sccs-comb(1)
sccs-delta(1)
sccsdiff(1)
sccs-get(1)
sccs-help(1)
sccs-prs(1)
sccs-prt(1)
sccs-rmdel(1)
sccs-sact(1)
sccs-sccsdiff(1)
sccs-unget(1)
sccs-val(1)
scp(1)
script(1)
sdiff(1)
sed(1)
sed(1B)
select(1)
set(1)
setenv(1)
setfacl(1)
setlabel(1)
setpgrp(1)
settime(1)
sftp(1)
sh(1)
shcomp(1)
shell_builtins(1)
shift(1)
shutdown(1B)
size(1)
sleep(1)
smbutil(1)
snca(1)
soelim(1)
sort(1)
sortbib(1)
sotruss(1)
source(1)
sparc(1)
spell(1)
spellin(1)
split(1)
srchtxt(1)
ssh(1)
ssh-add(1)
ssh-agent(1)
ssh-http-proxy-connect(1)
ssh-keygen(1)
ssh-keyscan(1)
ssh-socks5-proxy-connect(1)
stop(1)
strchg(1)
strconf(1)
strings(1)
strip(1)
stty(1)
stty(1B)
sum(1)
sum(1B)
sun(1)
suspend(1)
svcprop(1)
svcs(1)
switch(1)
symorder(1)
sys-suspend(1)
sysV-make(1)
t300(1)
t300s(1)
t4014(1)
t450(1)
tabs(1)
tail(1)
talk(1)
tar(1)
tbl(1)
tcopy(1)
tee(1)
tek(1)
telnet(1)
test(1)
test(1B)
tftp(1)
time(1)
timemanp(1)
times(1)
timesysp(1)
timex(1)
tip(1)
tnfdump(1)
tnfxtract(1)
touch(1)
touch(1B)
tplot(1)
tput(1)
tr(1)
tr(1B)
trap(1)
troff(1)
true(1)
truss(1)
tset(1B)
tsort(1)
tty(1)
type(1)
typeset(1)
u370(1)
u3b(1)
u3b15(1)
u3b2(1)
u3b5(1)
ul(1)
ulimit(1)
umask(1)
unalias(1)
uname(1)
uncompress(1)
unexpand(1)
unget(1)
unhash(1)
unifdef(1)
uniq(1)
units(1)
unix2dos(1)
unlimit(1)
unpack(1)
unset(1)
unsetenv(1)
until(1)
uptime(1)
userattr(1)
users(1B)
uucp(1C)
uudecode(1C)
uuencode(1C)
uuglist(1C)
uulog(1C)
uuname(1C)
uupick(1C)
uustat(1C)
uuto(1C)
uux(1C)
vacation(1)
val(1)
valdate(1)
valgid(1)
valint(1)
valpath(1)
valrange(1)
valstr(1)
valtime(1)
valuid(1)
valyorn(1)
vax(1)
vc(1)
vedit(1)
ver(1)
vgrind(1)
vi(1)
view(1)
vipw(1B)
volcheck(1)
volrmmount(1)
w(1)
wait(1)
wc(1)
what(1)
whatis(1)
whence(1)
whereis(1B)
which(1)
while(1)
who(1)
whoami(1B)
whocalls(1)
whois(1)
write(1)
xargs(1)
xgettext(1)
xstr(1)
yacc(1)
yes(1)
ypcat(1)
ypmatch(1)
yppasswd(1)
ypwhich(1)
zcat(1)
zlogin(1)
zonename(1)
zonestat(1)
sccs-help
, help
- ask for help regarding SCCS error or warning messages
Synopsis
/usr/ccs/bin/help [argument]...
Description
The help utility retrieves information to further explain errors messages and warnings from SCCS commands. It also provides some information about SCCS command usage. If no arguments are given, help prompts for one.
An argument may be a message number (which normally appears in parentheses following each SCCS error or warning message), or an SCCS command name. help responds with an explanation of the message or a usage line for the command.
When all else fails, try `/usr/ccs/bin/help stuck'.
Files
/usr/lib/help
directory containing files of message text
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
SUNWsprot
See Also
sccs(1), sccs-admin(1), sccs-cdc(1), sccs-comb(1), sccs-delta(1), sccs-get(1), sccs-prs(1), sccs-prt(1), sccs-rmdel(1), sccs-sact(1), sccs-sccsdiff(1), sccs-unget(1), sccs-val(1), what(1), sccsfile(4), attributes(5)
