Skip Navigation Links
Exit Print View
man pages section 2: System Calls     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
Preface
Introduction
System Calls
access(2)
acct(2)
acl(2)
adjtime(2)
alarm(2)
audit(2)
auditon(2)
brk(2)
chdir(2)
chmod(2)
chown(2)
chroot(2)
close(2)
creat(2)
dup(2)
exec(2)
execl(2)
execle(2)
execlp(2)
execv(2)
execve(2)
execvp(2)
_Exit(2)
_exit(2)
exit(2)
faccessat(2)
facl(2)
fchdir(2)
fchmod(2)
fchmodat(2)
fchown(2)
fchownat(2)
fchroot(2)
fcntl(2)
fgetlabel(2)
fork1(2)
fork(2)
forkall(2)
forkallx(2)
forkx(2)
fpathconf(2)
fstat(2)
fstatat(2)
fstatvfs(2)
futimens(2)
futimesat(2)
getacct(2)
getaudit(2)
getaudit_addr(2)
getauid(2)
getcontext(2)
getdents(2)
getegid(2)
geteuid(2)
getgid(2)
getgroups(2)
getisax(2)
getitimer(2)
getlabel(2)
getmsg(2)
getpflags(2)
getpgid(2)
getpgrp(2)
getpid(2)
getpmsg(2)
getppid(2)
getppriv(2)
getprojid(2)
getrctl(2)
getrlimit(2)
getsid(2)
gettaskid(2)
getuid(2)
getustack(2)
ioctl(2)
issetugid(2)
kill(2)
lchown(2)
link(2)
linkat(2)
llseek(2)
lseek(2)
lstat(2)
_lwp_cond_broadcast(2)
_lwp_cond_reltimedwait(2)
_lwp_cond_signal(2)
_lwp_cond_timedwait(2)
_lwp_cond_wait(2)
_lwp_continue(2)
_lwp_info(2)
_lwp_kill(2)
_lwp_mutex_lock(2)
_lwp_mutex_trylock(2)
_lwp_mutex_unlock(2)
_lwp_self(2)
_lwp_sema_init(2)
_lwp_sema_post(2)
_lwp_sema_trywait(2)
_lwp_sema_wait(2)
_lwp_suspend(2)
memcntl(2)
meminfo(2)
mincore(2)
mkdir(2)
mkdirat(2)
mknod(2)
mknodat(2)
mmap(2)
mmapobj(2)
mount(2)
mprotect(2)
msgctl(2)
msgget(2)
msgids(2)
msgrcv(2)
msgsnap(2)
msgsnd(2)
munmap(2)
nice(2)
ntp_adjtime(2)
ntp_gettime(2)
open(2)
openat(2)
pathconf(2)
pause(2)
pcsample(2)
pipe(2)
poll(2)
p_online(2)
ppoll(2)
pread(2)
priocntl(2)
priocntlset(2)
processor_bind(2)
processor_info(2)
profil(2)
pset_assign(2)
pset_bind(2)
pset_create(2)
pset_destroy(2)
pset_getattr(2)
pset_info(2)
pset_list(2)
pset_setattr(2)
putacct(2)
putmsg(2)
putpmsg(2)
pwrite(2)
read(2)
readlink(2)
readlinkat(2)
readv(2)
rename(2)
renameat(2)
resolvepath(2)
rmdir(2)
sbrk(2)
semctl(2)
semget(2)
semids(2)
semop(2)
semtimedop(2)
setaudit(2)
setaudit_addr(2)
setauid(2)
setcontext(2)
setegid(2)
seteuid(2)
setgid(2)
setgroups(2)
setitimer(2)
setpflags(2)
setpgid(2)
setpgrp(2)
setppriv(2)
setrctl(2)
setregid(2)
setreuid(2)
setrlimit(2)
setsid(2)
settaskid(2)
setuid(2)
setustack(2)
shmat(2)
shmctl(2)
shmdt(2)
shmget(2)
shmids(2)
shmop(2)
sigaction(2)
sigaltstack(2)
sigpending(2)
sigprocmask(2)
sigsend(2)
sigsendset(2)
sigsuspend(2)
sigwait(2)
__sparc_utrap_install(2)
stat(2)
statvfs(2)
stime(2)
swapctl(2)
symlink(2)
symlinkat(2)
sync(2)
sysfs(2)
sysinfo(2)
time(2)
times(2)
uadmin(2)
ulimit(2)
umask(2)
umount(2)
umount2(2)
uname(2)
unlink(2)
unlinkat(2)
ustat(2)
utime(2)
utimensat(2)
utimes(2)
uucopy(2)
vfork(2)
vforkx(2)
vhangup(2)
waitid(2)
wracct(2)
write(2)
writev(2)
yield(2)
getppriv
, setppriv
- get or set a privilege set
Synopsis
#include <priv.h>
int getppriv(priv_ptype_t which, priv_set_t *set);
int setppriv(priv_op_t op, priv_ptype_t which, priv_set_t *set);
Description
The getppriv() function returns the process privilege set specified by which in the set pointed to by set. The memory for set is allocated with priv_allocset() and freed with priv_freeset(). Both functions are documented on the priv_addset(3C) manual page.
The setppriv() function sets or changes the process privilege set. The op argument specifies the operation and can be one of PRIV_OFF, PRIV_ON or PRIV_SET. The which argument specifies the name of the privilege set. The set argument specifies the set.
If op is PRIV_OFF, the privileges in set are removed from the process privilege set specified by which. There are no restrictions on removing privileges from process privileges sets, but the following apply:
If op is PRIV_ON, the privileges in set are added to the process privilege set specified by which. The following operations are permitted:
If op is PRIV_SET, the privileges in set replace completely the process privilege set specified by which. PRIV_SET is implemented in terms of PRIV_OFF and PRIV_ON. The same restrictions apply.
Return Values
Upon successful completion, 0 is returned. Otherwise, -1 is returned and errno is set to indicate the error.
Errors
The getppriv() and setppriv() functions will fail if:
EINVAL
The value of op or which is out of range.
EFAULT
The set argument points to an illegal address.
The setppriv() function will fail if:
EPERM
The application attempted to add privileges to PRIV_LIMIT or PRIV_PERMITTED, or the application attempted to add privileges to PRIV_INHERITABLE or PRIV_EFFECTIVE which were not in PRIV_PERMITTED.
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Interface Stability
Committed
MT-Level
MT-Safe
See Also
priv_addset(3C), attributes(5), privileges(5)
