Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- file tree traversal
#include <ftw.h>
The <ftw.h> header defines the FTW structure that includes the following members:
int base int level
The <ftw.h> header defines macros for use as values of the third argument to the application-supplied function that is passed as the second argument to ftw() and nftw() (see ftw(3C)):
file
directory
directory without read permission
directory with subdirectories visited
unknown type; stat() failed
symbolic link
symbolic link that names a nonexistent file
The <ftw.h> header defines macros for use as values of the fourth argument to nftw():
Physical walk, does not follow symbolic links. Otherwise, nftw() follows links but does not walk down any path that crosses itself.
The walk does not cross a mount point.
All subdirectories are visited before the directory itself.
The walk changes to each direct ory before reading it.
The <ftw.h> header defines the stat structure and the symbolic names for st_mode and the file type test macros as described in <sys/stat.h>.
Inclusion of the <ftw.h> header might also make visible all symbols from <sys/stat.h>.
