Skip Navigation Links | |
Exit Print View | |
man pages section 3: Library Interfaces and Headers Oracle Solaris 11 Express 11/10 |
SMHBA_GetAdapterAttributes(3LIB)
SMHBA_GetAdapterPortAttributes(3LIB)
SMHBA_GetBindingCapability(3LIB)
SMHBA_GetDiscoveredPortAttributes(3LIB)
SMHBA_GetFCPhyAttributes(3LIB)
SMHBA_GetPersistentBinding(3LIB)
SMHBA_GetPortAttributesByWWN(3LIB)
SMHBA_GetProtocolStatistics(3LIB)
SMHBA_GetSASPhyAttributes(3LIB)
SMHBA_GetVendorLibraryAttributes(3LIB)
SMHBA_GetWrapperLibraryAttributes(3LIB)
SMHBA_RegisterForAdapterAddEvents(3LIB)
SMHBA_RegisterForAdapterEvents(3LIB)
SMHBA_RegisterForAdapterPhyStatEvents(3LIB)
SMHBA_RegisterForAdapterPortEvents(3LIB)
SMHBA_RegisterForAdapterPortStatEvents(3LIB)
SMHBA_RegisterForTargetEvents(3LIB)
SMHBA_RemoveAllPersistentBindings(3LIB)
SMHBA_RemovePersistentBinding(3LIB)
- semaphores
#include <semaphore.h>
The <semaphore.h> header defines the sem_t type, used in performing semaphore operations. The semaphore can be implemented using a file descriptor, in which case applications are able to open up at least a total of {OPEN_MAX} files and semaphores. The symbol SEM_FAILED is defined (see sem_open(3C)).
Inclusion of the <semaphore.h> header can make visible symbols defined in the headers <fcntl.h> and <sys/types.h>. See fcntl.h(3HEAD) and types.h(3HEAD).
fcntl.h(3HEAD), types.h(3HEAD), sem_destroy(3C), sem_getvalue(3C), sem_init(3C), sem_open(3C), sem_post(3C), sem_timedwait(3C), sem_unlink(3C), sem_wait(3C), attributes(5), standards(5)
