Skip Navigation Links
Exit Print View
man pages section 9: DDI and DKI Driver Entry Points     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
Preface
Introduction
Driver Entry Points
aread(9E)
attach(9E)
audio_engine_channels(9E)
audio_engine_chinfo(9E)
audio_engine_close(9E)
audio_engine_count(9E)
audio_engine_format(9E)
audio_engine_open(9E)
audio_engine_playahead(9E)
audio_engine_qlen(9E)
audio_engine_rate(9E)
audio_engine_start(9E)
audio_engine_stop(9E)
audio_engine_sync(9E)
awrite(9E)
chpoll(9E)
close(9E)
csx_event_handler(9E)
detach(9E)
devmap(9E)
devmap_access(9E)
devmap_contextmgt(9E)
devmap_dup(9E)
devmap_map(9E)
devmap_unmap(9E)
dump(9E)
_fini(9E)
getinfo(9E)
gld(9E)
gldm_get_stats(9E)
gldm_intr(9E)
gldm_ioctl(9E)
gldm_reset(9E)
gldm_send(9E)
gldm_set_mac_addr(9E)
gldm_set_multicast(9E)
gldm_set_promiscuous(9E)
gldm_start(9E)
gldm_stop(9E)
identify(9E)
_info(9E)
_init(9E)
ioctl(9E)
ks_snapshot(9E)
ks_update(9E)
mac(9E)
mc_getcapab(9E)
mc_getprop(9E)
mc_getstat(9E)
mc_ioctl(9E)
mc_multicst(9E)
mc_propinfo(9E)
mc_setpromisc(9E)
mc_setprop(9E)
mc_start(9E)
mc_stop(9E)
mc_tx(9E)
mc_unicst(9E)
mmap(9E)
open(9E)
power(9E)
print(9E)
probe(9E)
prop_op(9E)
put(9E)
quiesce(9E)
read(9E)
segmap(9E)
srv(9E)
strategy(9E)
tran_abort(9E)
tran_bus_reset(9E)
tran_destroy_pkt(9E)
tran_dmafree(9E)
tran_getcap(9E)
tran_init_pkt(9E)
tran_pkt_constructor(9E)
tran_pkt_destructor(9E)
tran_quiesce(9E)
tran_reset(9E)
tran_reset_notify(9E)
tran_setcap(9E)
tran_setup_pkt(9E)
tran_start(9E)
tran_sync_pkt(9E)
tran_teardown_pkt(9E)
tran_tgt_free(9E)
tran_tgt_init(9E)
tran_tgt_probe(9E)
tran_unquiesce(9E)
write(9E)
read
- read data from a device
Synopsis
#include <sys/types.h>
#include <sys/errno.h>
#include <sys/open.h>
#include <sys/uio.h>
#include <sys/cred.h>
#include <sys/ddi.h>
#include <sys/sunddi.h>
int prefixread(dev_t dev, struct uio *uio_p, cred_t *cred_p);
Interface Level
Architecture independent level 1 (DDI/DKI). This entry point is optional.
Parameters
dev
Device number.
uio_p
Pointer to the uio(9S) structure that describes where the data is to be stored in user space.
cred_p
Pointer to the user credential structure for the I/O transaction.
Description
The driver read() routine is called indirectly through cb_ops(9S) by the read(2) system call. The read() routine should check the validity of the minor number component of dev and the user credential structure pointed to by cred_p (if pertinent). The read() routine should supervise the data transfer into the user space described by the uio(9S) structure.
Return Values
The read() routine should return 0 for success, or the appropriate error number.
Examples
Example 1 read() routine using physio()
The following is an example of a read() routine using physio(9F) to perform reads from a non-seekable device:
      static int
      xxread(dev_t dev, struct uio *uiop, cred_t *credp)
               int                 rval;
               offset_t            off;
               int                 instance;
               xx_t                xx;
               instance = getminor(dev);
               xx = ddi_get_soft_state(xxstate, instance);
               if (xx == NULL)
                         return (ENXIO);
               off = uiop->uio_loffset;
               rval = physio(xxstrategy, NULL, dev, B_READ,
                         xxmin, uiop);
               uiop->uio_loffset = off;
               return (rval);
See Also
read(2), write(9E), physio(9F), cb_ops(9S), uio(9S)
Writing Device Drivers
