Skip Navigation Links
Exit Print View
Multithreaded Programming Guide     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
1.  Covering Multithreading Basics
2.  Basic Threads Programming
3.  Thread Attributes
4.  Programming with Synchronization Objects
5.  Programming With the Solaris Software
6.  Programming With Solaris Threads
7.  Safe and Unsafe Interfaces
8.  Compiling and Debugging
9.  Programming Guidelines
Rethinking Global Variables
Providing for Static Local Variables
Synchronizing Threads
Single-Threaded Strategy
Reentrant Function
Code Locking
Data Locking
Invariants and Locks
Avoiding Deadlock
Deadlocks Related to Scheduling
Locking Guidelines
Finding Deadlocks
Some Basic Guidelines for Threaded Code
Creating and Using Threads
Working With Multiprocessors
Underlying Architecture
Shared-Memory Multiprocessors
Peterson's Algorithm
Parallelizing a Loop on a Shared-Memory Parallel Computer
Examples of Threads Programs
Further Reading
A.  Extended Example: A Thread Pool Implementation
Historically, most code has been designed for single-threaded programs. This code design is especially true for most of the library routines that are called from C programs. The following implicit assumptions were made for single-threaded code:
The following examples discuss some of the problems that arise in multithreaded programs because of these assumptions, and how you can deal with the problems.
Traditional, single-threaded C and UNIX have a convention for handling errors detected in system calls. System calls can return anything as a functional value. For example, write() returns the number of bytes that were transferred. However, the value -1 is reserved to indicate that something went wrong. So, when a system call returns -1, you know that the call failed.
Example 9-1 Global Variables and errno
extern int errno;
if (write(file_desc, buffer, size) == -1) {
    /* the system call failed */
    fprintf(stderr, “something went wrong, “
        “error code = %d\n”, errno);
Rather than returning the actual error code, which could be confused with normal return values, the error code is placed into the global variable errno. When the system call fails, you can look in errno to find out what went wrong.
Now, consider what happens in a multithreaded environment when two threads fail at about the same time but with different errors. Both threads expect to find their error codes in errno, but one copy of errno cannot hold both values. This global variable approach does not work for multithreaded programs.
Threads solve this problem through a conceptually new storage class: thread-specific data. This storage is similar to global storage. Thread-specific data can be accessed from any procedure in which a thread might be running. However, thread-specific data is private to the thread. When two threads refer to the thread-specific data location of the same name, the threads are referring to two different areas of storage.
So, when using threads, each reference to errno is thread specific because each thread has a private copy of errno. A reference to errno as thread-specific is achieved in this implementation by making errno a macro that expands to a function call.
