Skip Navigation Links
Exit Print View
Multithreaded Programming Guide     Oracle Solaris 11 Express 11/10
search filter icon
search icon
Document Information
1.  Covering Multithreading Basics
2.  Basic Threads Programming
3.  Thread Attributes
4.  Programming with Synchronization Objects
5.  Programming With the Solaris Software
6.  Programming With Solaris Threads
7.  Safe and Unsafe Interfaces
8.  Compiling and Debugging
9.  Programming Guidelines
Rethinking Global Variables
Providing for Static Local Variables
Synchronizing Threads
Single-Threaded Strategy
Reentrant Function
Code Locking
Data Locking
Invariants and Locks
Avoiding Deadlock
Deadlocks Related to Scheduling
Locking Guidelines
Finding Deadlocks
Some Basic Guidelines for Threaded Code
Creating and Using Threads
Working With Multiprocessors
Underlying Architecture
Shared-Memory Multiprocessors
Peterson's Algorithm
Parallelizing a Loop on a Shared-Memory Parallel Computer
Examples of Threads Programs
Further Reading
A.  Extended Example: A Thread Pool Implementation
The threads packages cache the threads data structure and stacks so that the repetitive creation of threads can be reasonably inexpensive. However, creating and destroying threads as the threads are required is usually more expensive than managing a pool of threads that wait for independent work. A good example is an RPC server that creates a thread for each request and destroys the thread when the reply is delivered.
Thread creation has less overhead than the overhead of process creation. However, thread creation is not efficient when compared to the cost of creating a few instructions. Create threads for processing that lasts at least a couple of thousand machine instructions.
