Skip Navigation Links
Exit Print View
Sun Storage 2500-M2 Arrays
Hardware Release Notes, Release 6.10
search filter icon
search icon
Document Information
1.  Sun Storage 2500-M2 Arrays Hardware Release Notes
What's New in This Release
Product Overview
About the Management Software
System Requirements
Firmware Requirements
Supported Disk Drives and Tray Capacity
Array Expansion Module Support
Data Host Requirements
Multipathing Software
Supported Host Bus Adaptors (HBAs)
Supported FC and Multilayer Switches
Expansion Tray Specifications
ALUA/TPGS Multipathing with VMware
Procedure for ESX4.1U2 and ESXi5.0
Procedure for ESX4.1U3 and ESXi5.0U1
Restrictions and Known Issues
Restrictions
Single Path Data Connections
SAS Host Ports on the Sun Storage 2540-M2
Controller Issues
Log Events With smartd Monitoring Enabled
After Re-Installing the Oracle Virtual Machine (OVM) Manager, International Standards Organizations (ISO) Files Are Listed by Universally Unique Identifier (UUID) Rather Than by Friendly Name
After Un-Mapping a Volume from an Oracle Virtual Machine (OVM) Server, the Volume Continues to Appear in the Storage Database on the Server
In the Oracle Virtual Machine (OVM) Manager User Interface, Only One Drive at a Time Can Be Selected for Deletion
Kernel Panics During Controller Firmware (CFW) Download
BCM Driver Fails to Load
Kernel Panics During Controller Firmware Download
Network Interface on Device eth0 Fails to Come Online When Booting a Host
When Over 128 Volumes are Mapped to a Host, Paths to Only the First 128 Volumes are Restored after the Controller is Reset
Tasks Aborts Are Logged During a Controller Firmware Upgrade
Unable to Add More Than 117 Volumes to the Oracle Virtual Machine (OVM) Manager Database
Write-Back Cache is Disabled after Controllers Reboot with Multiple Failed Volumes in a Storage Array
During Multiple Node Failover/Failback Events, Input/Output (I/O) Operations Time Out Because a Resource is Not Available to a Cluster
After an NVSRAM Download, a Controller Reboots a Second Time when the NVSRAM is Activated
When a Controller is Not Set Offline Before Being Replaced, an Exception Occurs when the Replacement Controller is Brought Online
Input/Output (I/O) Errors Occur when Disconnection of Devices from a SAS Switch Is Not Detected
A Path Failure and Premature Failover Occur when a Cable is Disconnected between a Host and a Controller
Input/Output (I/O) Errors Occur when a Cable is Disconnected between a Host and a Controller, and the Alternate Controller is Unavailable
With 3 Gb/s SAS Host Bus Adapters (HBAs) and Heavy Input/Output (I/O), I/O Timeouts Occur During a Controller Firmware Upgrade
Host Operating System Logs "Hung Task" During a Path Failure
Backup Failure or I/O Errors with Snapshot Creation or Mounting Failure During Backup of Cluster Shared Volumes (CSV)
With Multiple SAS Hosts Using Single‐PHY, a Host Cable Pull During Input/Output (I/O) Operations Causes a Controller Reboot
Data is Misread when a Physical Drive Has an Unreadable Sector
Solaris 10 Guest in Fault Tolerant Mode Is Unable to Relocate Secondary Virtual Machine (VM) Upon Host Failure
Documentation Bugs
Hardware Installation Guide
Related Documentation
Documentation, Support, and Training
The following procedures describe how to enable ALUA/TPGS multipathing with VMware support to an array. Starting with firmware 07.84.44.10, multipathing to ALUA/TPGS-enabled arrays is provided by the VMW_SATP_ALUA plug-in. Arrays with firmware previous to 07.84.44.10 use the VMW_SATP_LSI plug-in.
Prerequisites:
Note - The path policy supported is Round-Robin (RR) or Most Recently Used (MRU).
VMware versions ESX4.1u1/u2 and ESXi5.0 (and earlier) do not automatically enable ALUA/TPGS multipathing for arrays that offer this feature. You must manually enable multipathing as described below.
VID/PID values:
  1. Install CAM software with firmware version 07.84.44.10 (minimum) on the management host.
  2. To enable ALUA/TPGS multipathing support for ESX 4.1Ux or ESX 5.0:
    • For ESX 4,1, open a terminal to the ESX host and run the commands:
      # esxcli nmp satp deleterule -s VMW_SATP_LSI -V SUN -M LCSM100_F
      # esxcli nmp satp addrule -s VMW_SATP_LSI -V SUN -M LCSM100_F -c tpgs_off
      Reboot the ESX host.
    • For ESXi 5.0, open a terminal to the ESX host and run the following command:
      # esxcli storage nmp satp rule add -s VMW_SATP_ALUA -V SUN -M LCSM100_F -c tpgs_on
  3. Verify the claim rule is added in ESX.
    For ESX 4.1:
    1. Show a list of all the claim rules:
      # esxcli nmp satp listrules
    2. List only the claim rules for the VMW_SATP_LSI:
      # esxcli nmp satp listrules -s VMW_SATP_LSI
    3. Verify the VID/PID is SUN/LCSM100_F for 2540-M2 (or SUN/LCSM100_S for 2530-M2) and the Claim Options flag tpgs_off is set.
    For ESXi 5.0:
      # esxcli storage nmp satp rule list
    2. List only the claim rules for the VMW_SATP_ALUA:
      # esxcli storage nmp satp rule list -s VMW_SATP_ALUA
    3. Verify the VID/PID for VMW_SATP_ALUA is SUN/LCSM100_F for 2540-M2 (or SUN/LCSM100_S for 2530-M2) and the Claim Options flag tpgs_on is set.
  4. Upgrade the controller firmware to 07.84.44.10 (minimum) and its corresponding NVSRAM version via the management host. The controller firmware and NVSRAM are part of the CAM baseline.
  5. Using CAM, verify the VM host initiator host type is set to VMWARE. Starting with firmware 07.84.44.10, the VMWARE host type defaults to ALUA/TPGS multipathing.
  6. On the ESX host, perform a manual re-scan.
  7. Verify the 7.84 ALUA-enabled arrays have the VMW_SATP_ALUA plug-in, as follows.
    • For ESX 4,1, run the command:
      # esxcli nmp device list
    • For ESXi 5.0, run the command:
      # esxcli storage nmp device list
    For LUNs from arrays with firmware version 07.84.44.10 (and later), the value is VMW_SATP_ALUA. For LUNs from arrays with firmware version previous to 07.84.44.10, the value is VMW_SATP_LSI.
Starting with ESX4.1U3 and ESXi5.0 U1, VMware automatically enables the VMW_SATP_ALUA plug-in for arrays that offer ALUA/TPGS multipathing.
  2. Upgrade the controller firmware to 07.84.44.10 (minimum) and its corresponding NVSRAM version via the management host. The controller firmware and NVSRAM are part of the CAM baseline.
  3. Using CAM, verify the VM host initiator host type is set to VMWARE. Starting with firmware 07.84.44.10, the VMWARE host type defaults to ALUA/TPGS multipathing.
  4. On the ESX host, perform a manual re-scan.
  5. Verify the VMW_SATP_ALUA plug-in is enabled.
    • For ESX 4.1, run the command:
