Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Installation Guide for VMware ESXi
search filter icon
search icon
Document Information
Using This Documentation
1.  About VMware ESXi Installs
VMware ESXi Installation Task Map
Supported VMware ESXi Software
Selecting the Console Display Option
Console Display Options
Set Up the Local Console
Set Up the Remote Console
Selecting the Boot Media Option
Boot Media Options Requirements
Set Up the Local Boot Media Option
Set Up the Remote Boot Media Option
Selecting the Installation Target Option
Installation Target Options
Set Up a Local Storage Drive (HDD or SSD) as the Installation Target
Set Up a Fibre Channel Storage Area Network Device as the Installation Target
VMware ESXi Installation Options
Single-Server Installation Methods
2.  Preparing to Install VMware ESXi
Setting Up BIOS
Verify the BIOS Factory Defaults
Configuring RAID
3.  Installing VMware ESXi
Before You Begin
Installing VMware ESXi on a Single System Using Media
Install VMware ESXi Using Local or Remote Media
4.  Post Installation Tasks for VMware ESXi
Configuring Network Adapter Settings
Configure Network Adapter Settings
Determining the MAC Address of a Connected Server Network Port
Determine the MAC Address of a Connected Server Network Port
Updating the VMware ESXi Software
VMware ESXi Resources
5.  Configuring Network Interfaces
NIC Connectors
6.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Software Releases
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Installing Updates Using Other Methods
Index
Configuring RAID
If you want to use redundant array of independent disks (RAID), you must configure RAID on your server before you install VMware ESXi. You can use Oracle Hardware Installation Assistant or Oracle Hardware Management Pack to configure RAID on your server. For instructions for configuring RAID, see the Sun Server X2-4 Installation Guide.
