Skip Navigation Links
Exit Print View
Oracle Java CAPS Adapter for Oracle Tutorials     Java CAPS Documentation
search filter icon
search icon
Document Information
About the Oracle Java CAPS Adapter for Oracle Sample Projects
Sample Input Trigger Files and Output Files
Sample Project Data
Operations Used in the Oracle Sample Projects
About the Oracle Java CAPS Business Process Manager Project
Associating Business Process Manager Operators
Deploying JCD- Based Operations in the Business Process Manager
About the Java Collaboration Definition Sample Project
Importing Non-JBI Based Sample Projects
To Import a Non-JBI Based Sample Project
Running the SQL Script
Creating the Java Collaboration Definition-Based Project for the Oracle Java CAPS Adapter for Oracle
Creating a New Project
Create a Project
Creating the OTDs
Create the Oracle Database OTD
Create the Inbound and Outbound DTD OTDs
Creating the Collaboration Definitions (Java)
Create the jcdDelete Collaboration Definition
Using the Java Collaboration Editor to create Business Rules
Creating the Business Rules for the jcdDelete Collaboration
Create the jcdDelete Collaboration Business Rules
jcdDelete Collaboration Java Code
Creating the Business Rules for the jcdInsert Collaboration
Create the jcdInsert Collaboration Business Rules
jcdInsert Collaboration Java Code
Creating the Business Rules for the jcdPsSelect Collaboration
Using the Collaboration Editor's Java Source Editor
Create the jcdPsSelect Collaboration Business Rules
Creating the Business Rules for the jcdTableSelect Collaboration
Create the jcdTableSelect Collaboration Business Rules
jcdTableSelect Collaboration Java Code
Creating the Business Rules for the jcdUpdate Collaboration
Create the jcdUpdate Collaboration Business Rules
jcdUpdate Collaboration Java Code
Next Steps
Creating the Connectivity Maps
Adding Connectivity Maps to a Project
Add the Connectivity Maps to the Project
Populating and Binding the Connectivity Maps using the Connectivity Map Generator
Populate the Connectivity Maps using the Connectivity Map Generator.
Creating an Environment
Create the Environment
Configuring the Adapter Properties
Configuring the Connectivity Map Properties
Configure the Connectivity Map Properties
File1 Inbound Adapter Properties
File2 Outbound Adapter Properties
Oracle1 Outbound Adapter Properties
Configuring the Environment Properties
Configure the Environment Properties
File Adapter Environment Properties
Oracle Adapter Environment Properties
What's the Next Step?
Creating the Deployment Profile
Create the Deployment Profile
Building and Deploying the Project
Building the Project
Build the Project
Deploying the Project from NetBeans
Deploy the Project
Running the Project
Run the project
Creating the BPEL-Based Project for the Oracle Java CAPS Adapter for Oracle
Creating the Business Processes
Create the bpDelete Business Process
Create the bpInsert Business Process
Create the bpPsSelect Business Process
Create the bpTableSelect Business Process
Create the bpUpdate Business Process
Using Business Process Designer to Create Business Rules
Creating the bpDelete Business Rules
Create the bpDelete Business Rules
Creating the bpInsert Business Rules
Create the bpInsert Business Rules
Creating the bpPsSelect Business Rules
Create the bpPsSelect Business Rules
Creating the bpTableSelect Business Rules
Create the bpTableSelect Business Rules
Creating the bpUpdate Business Rules
Create the bpUpdate Business Rules
First, you create a new project in the NetBeans IDE
Create a Project
  1. Start the NetBeans IDE
  2. Click the New Project icon, or select File -> New Project to initiate the New Project wizard.
  3. In Step 1 of the Wizard, select CAPS -> ESB from the Categories column, CAPS Repository-Based Project from the Projects column, and click Next.
  4. In Step 2 of the Wizard, specify your project name (for this project, use prjOracle_JCD if you are creating the Java Collaboration-based project, or prjOracle_BPEL if you are creating the Business Process-based project), and click Finish.
Next Steps
For your next step, see Creating the OTDs.
