Skip Navigation Links
Exit Print View
Netra SPARC T4-2 Server
Product Notes
search filter icon
search icon
Document Information
Using This Documentation
1.  Late-Breaking Information
General Notes
16 GB Dual-Rank DIMMs and System Firmware
Preinstalled Software
Supported Oracle Solaris OS and Firmware Information
OS Package and Patch Updates
Oracle Solaris 11 OS Package Updates
Patch Updates for Oracle Solaris 10 8/11
Downloading Patches and Software Updates
Download Patches
Download Software Updates
2.  Known Product Issues
Hardware Issues
Sun Storage 6 Gb SAS PCIe RAID HBA, Internal PCIe Card Must Be Installed in PCIe Slot 5
Certain PCIe Cards With Large Connectors Can Not Be Installed in Slot 7 (CR 7110077)
Direct I/O Support
Downloading sas2ircu Documentation for SPARC T4 Servers
Sun Type 6 Keyboards Are Not Supported by SPARC T4 Series Servers
L2 Cache UEs Are Sometimes Reported as Core Faults Without Any Cache Line Retirements (CR 7071237)
Upon a Reboot After an Unrecoverable Hardware Error, CPUs Might Not Start (CR 7075336)
Oracle Solaris OS Issues
Spurious Error Message During Initial Oracle Solaris OS Installation (CR 6971896)
When diag-switch? Is Set to true, Oracle Solaris OS Fails to Update EEPROM for Automatic Rebooting (CR 6982060)
The cfgadm Command Fails for Certain HBAs (CR 7044759)
Firmware Issues
sas2ircu Message That RAID Volume Sizes Other Than MAX Are Not Supported Needs Clarification (CR 6983210)
Blue LED on Drive Does Not Light When the Drive Is Ready to Remove (CR 7082700)
Firmware Issues
This section describes issues related to the system firmware.
If you attempt to create a RAID volume smaller than MAX, the following series of messages is returned:
You are about to create an IR volume.
WARNING: Proceeding with this operation may cause data loss or data
         corruption. Are you sure you want to proceed (YES/NO)? yes
WARNING: Volume created with size other than 'MAX' is not supported.
         Do you want to continue with volume creation (YES/NO)? n
SAS2IRCU: you must answer "YES" or "yes" to proceed; operation aborted!
SAS2IRCU: Error executing command CREATE.
RAID volumes smaller than MAX are not supported. However, if you want to create a volume below MAX size for nonproduction use, the software will allow you to do so. This situation is not clear from the message.
Workaround: Ignore the messages and answer yes for the question “Do you want to continue with volume creation (YES/NO)?”.
When you attempt to unconfigure a drive for removal, the drive's blue LED that indicates the drive is ready for removal might not light. This situation occurs after you place a drive in a slot in place of a drive that had a different WWN.
Workaround: If you inserted a drive after booting the server, realize that the blue LED does not perform this function until the server has booted again.
