Skip Navigation Links
Exit Print View
Oracle Fusion Middleware Deployment Planning Guide for Oracle Unified Directory 11g Release 1 (11.1.1)
search filter icon
search icon
Document Information
Preface
1.  Overview of Oracle Unified Directory
2.  Overview of the Directory Server
3.  Overview of the Proxy Server
4.  Overview of the Replication Gateway
5.  Building Blocks of the Proxy Server
6.  Example Deployments Using the Directory Server
7.  Example Deployments Using the Proxy Server
8.  Simple Proxy Deployments Using the Command Line Interface
9.  Deploying Advanced Proxy Architectures
Configuring Failover Between Data Centers
Configuring Distribution with Failover Between Data Centers
Use the following commands to set up a failover deployment between two data centers, as presented in Configuration 3: Failover Between Data Centers.
#Create a proxy LDAP extension for each remote LDAP server
dsconfig -p 4444 -h localhost -D"cn=Directory Manager" -w password -X -n \
create-extension \
  --type ldap-server \
  --extension-name proxy-extension1 \
  --set enabled:true \
  --set remote-ldap-server-address:DS1_hostname \
  --set remote-ldap-server-port:3189
create-extension \
  --extension-name proxy-extension2 \
  --set remote-ldap-server-address:DS2_hostname \
  --set remote-ldap-server-port:3289
create-extension \
  --extension-name proxy-extension3 \
  --set remote-ldap-server-address:DS3_hostname \
  --set remote-ldap-server-port:3389
create-extension \
  --extension-name proxy-extension4 \
  --set remote-ldap-server-address:DS4_hostname \
  --set remote-ldap-server-port:3489
#Create a proxy workflow element for each LDAP server extension
create-workflow-element \
  --element-name proxy-we1 \
  --type proxy-ldap \
  --set client-cred-mode:use-client-identity \
  --set ldap-server-extension:proxy-extension1
  --element-name proxy-we2 \
  --type proxy-ldap \
  --set ldap-server-extension:proxy-extension2
  --element-name proxy-we3 \
  --type proxy-ldap \
  --set ldap-server-extension:proxy-extension3
  --element-name proxy-we4 \
  --type proxy-ldap \
  --set ldap-server-extension:proxy-extension4
# Create a load balancing workflow element for each data center
  --element-name LB-we1 \
  --type load-balancing \
  --set enabled:true
  --element-name LB-we2 \
  --set enabled:true
# Define the load balancing algorithm for each data center
create-load-balancing-algorithm \
  --type proportional
  --type proportional
# Define the load balancing routes for each proxy
create-load-balancing-route \
  --route-name LB-route1 \
  --type proportional \
  --set workflow-element:proxy-we1
  --route-name LB-route2 \
  --set workflow-element:proxy-we2
  --route-name LB-route3 \
  --set workflow-element:proxy-we3
  --route-name LB-route4 \
  --set workflow-element:proxy-we4
# Set failover between the two data centers
  --element-name FO-we \
  --set enabled:true
  --type failover
  --route-name FO-route1 \
  --type failover \
  --set workflow-element:LB-we1 \
  --set add-priority:1 \
--set bind-priority:1 \
--set compare-priority:1 \
--set delete-priority:1 \
--set extended-priority:1 \
--set modify-priority:1 \
--set modifydn-priority:1 \
--set search-priority:1 \
  --route-name FO-route2 \
  --type failover \
  --set workflow-element:LB-we2 \
  --set add-priority:2 \
--set bind-priority:2 \
--set compare-priority:2 \
--set delete-priority:2 \
--set extended-priority:2 \
--set modify-priority:2 \
--set modifydn-priority:2 \
--set search-priority:2 \
# Create workflow
create-workflow \
  --workflow-name FO-workflow \
  --set base-dn:dc=example,dc=com \
  --set workflow-element:FO-we
# Create network group
create-network-group \
  --group-name network-group1 \
  --set workflow:FO-workflow \
  --set priority:1
