Note: this is an abstract component, that cannot be instantiated.
Monitor Providers can be used to provide information about the state of the server or one of its components.
This information is useful for monitoring or troubleshooting.
The following Monitor Providers are available in the server :
These Monitor Providers inherit from the properties described below.
A description of each property follows.
Basic Properties: | Advanced Properties: |
↓ enabled | None |
↓ java-class |
Description | Indicates whether the Monitor Provider is enabled for use. |
Default Value | None |
Allowed Values | true false |
Multi-valued | No |
Required | Yes |
Admin Action Required | None |
Advanced Property | No |
Read-only | No |
Description | Specifies the fully-qualified name of the Java class that provides the Monitor Provider implementation. |
Allowed Values | A java class that implements or extends the class(es) : org.opends.server.api.MonitorProvider |
Multi-valued | No |
Required | Yes |
Read-only | No |
