Skip Navigation Links
Exit Print View
System Administration Guide: Network Services     Oracle Solaris 10 8/11 Information Library
search filter icon
search icon
Document Information
Preface
Part I Network Services Topics
1.  Network Service (Overview)
2.  Managing Web Cache Servers
3.  Time-Related Services
Part II Accessing Network File Systems Topics
4.  Managing Network File Systems (Overview)
5.  Network File System Administration (Tasks)
6.  Accessing Network File Systems (Reference)
Part III SLP Topics
7.  SLP (Overview)
8.  Planning and Enabling SLP (Tasks)
9.  Administering SLP (Tasks)
10.  Incorporating Legacy Services
11.  SLP (Reference)
Part IV Mail Services Topics
12.  Mail Services (Overview)
13.  Mail Services (Tasks)
14.  Mail Services (Reference)
Part V Serial Networking Topics
15.  Solaris PPP 4.0 (Overview)
16.  Planning for the PPP Link (Tasks)
17.  Setting Up a Dial-up PPP Link (Tasks)
18.  Setting Up a Leased-Line PPP Link (Tasks)
19.  Setting Up PPP Authentication (Tasks)
20.  Setting Up a PPPoE Tunnel (Tasks)
21.  Fixing Common PPP Problems (Tasks)
22.  Solaris PPP 4.0 (Reference)
Using PPP Options in Files and on the Command Line
Where to Define PPP Options
How PPP Options Are Processed
How PPP Configuration File Privileges Work
User Privileges
File Privileges
Effects of Option Privileges
/etc/ppp/options Configuration File
/etc/ppp/options.tmpl Template
Where to Find Examples of the /etc/ppp/options Files
/etc/ppp/options.ttyname Configuration File
Using /etc/ppp/options.ttyname on a Dial-in Server
Using /etc/ppp/options.ttyname on a Dial-out Machine
options.ttya.tmpl Template File
Where to Find Examples of the /etc/ppp/options.ttyname Files
Configuring User-Specific Options
Configuring $HOME/.ppprc on a Dial-in Server
Configuring $HOME/.ppprc on a Dial-out Machine
Specifying Information for Communicating With the Dial-in Server
/etc/ppp/peers/peer-name File
/etc/ppp/peers/myisp.tmpl Template File
Where to Find Examples of the /etc/ppp/peers/peer-name Files
Configuring Modem Speed for a Dial-up Link
Defining the Conversation on the Dial-up Link
Contents of the Chat Script
Chat Script Examples
Basic Modem Chat Script
/etc/ppp/myisp-chat.tmpl Chat Script Template
Modem Chat Script for Calling an ISP
Basic Chat Script Enhanced for a UNIX-Style Login
Chat Script for External ISDN TA
For More Chat Script Examples
Invoking the Chat Script
How to Invoke a Chat Script (Task)
Creating a Chat File That Is Executable
How to Create an Executable Chat Program
Authenticating Callers on a Link
Password Authentication Protocol (PAP)
/etc/ppp/pap-secrets File
Creating PAP Passwords
What Happens During PAP Authentication
Using the login Option With /etc/ppp/pap-secrets
Challenge-Handshake Authentication Protocol (CHAP)
/etc/ppp/chap-secrets File
What Happens During CHAP Authentication
Creating an IP Addressing Scheme for Callers
Assigning Dynamic IP Addresses to Callers
Assigning Static IP Addresses to Callers
Assigning IP Addresses by sppp Unit Number
Creating PPPoE Tunnels for DSL Support
Files for Configuring Interfaces for PPPoE
/etc/ppp/pppoe.if File
/usr/sbin/sppptun Command
Examples of sppptun Commands for Administering Interfaces
PPPoE Access Server Commands and Files
/usr/lib/inet/pppoed Daemon
/etc/ppp/pppoe File
/etc/ppp/pppoe.device File
pppoe.so Plugin
Using PPPoE and PPP Files to Configure an Access Server
PPPoE Client Commands and Files
/usr/lib/inet/pppoec Utility
pppoe.so Shared Object
/etc/ppp/peers/peer-name File for Defining an Access Server Peer
23.  Migrating From Asynchronous Solaris PPP to Solaris PPP 4.0 (Tasks)
24.  UUCP (Overview)
25.  Administering UUCP (Tasks)
26.  UUCP (Reference)
Part VI Working With Remote Systems Topics
27.  Working With Remote Systems (Overview)
28.  Administering the FTP Server (Tasks)
29.  Accessing Remote Systems (Tasks)
Part VII Monitoring Network Services Topics
30.  Monitoring Network Performance (Tasks)
Glossary
Index
This section explains how the PPP authentication protocols work and explains the databases that are associated with the authentication protocols.
PAP authentication is somewhat similar in operation to the UNIX login program, though PAP does not grant shell access to the user. PAP uses the PPP configuration files and PAP database in the form of the /etc/ppp/pap-secrets file for setting up authentication. PAP also uses /etc/ppp/pap-secrets for defining PAP security credentials. These credentials include a peer name, a “user name” in PAP parlance, and a password. PAP credentials also contain related information for each caller who is permitted to link to the local machine. The PAP user names and passwords can be identical to or different from the UNIX user names and passwords in the password database.
The PAP database is implemented in the /etc/ppp/pap-secrets file. Machines on both sides of the PPP link must have properly configured PAP credentials in their /etc/ppp/pap-secrets files for successful authentication. The caller (authenticatee) supplies credentials in the user and password columns of the /etc/ppp/pap-secrets file or in the obsolete +ua file. The server (authenticator) validates these credentials against information in /etc/ppp/pap-secrets, through the UNIX passwd database, or in the PAM facility.
The /etc/ppp/pap-secrets file has the following syntax.
myclient ISP-server mypassword *
The parameters have the following meaning.
myclient
PAP user name of the caller. Often, this name is identical to the caller's UNIX user name, particularly if the dial-in server uses the login option of PAP.
ISP-server
Name of the remote machine, often a dial-in server.
mypassword
Caller's PAP password.
IP address that is associated with the caller. Use an asterisk (*) to indicate any IP address.
PAP passwords are sent over the link in the clear, that is, in readable ASCII format. For the caller (authenticatee), the PAP password must be stored in the clear in any of the following locations:
On the server (authenticator), the PAP password can be hidden by doing one of the following:
PAP authentication occurs in the following sequence.
Figure 22-1 PAP Authentication Process
image:The following context describes the sequence that is shown in the flow diagram.
  1. The caller (authenticatee) calls the remote peer (authenticator) and provides its PAP user name and password as part of link negotiation.
  2. The peer verifies the identity of the caller in its /etc/ppp/pap-secrets file. If the peer uses the login option of PAP, the peer verifies the caller's user name and password in its password database.
  3. If authentication is successful, the peer continues link negotiation with the caller. If authentication fails, the link is dropped.
  4. (Optional) If the caller authenticates responses from remote peers, the remote peer must send its own PAP credentials to the caller. Thus, the remote peer becomes the authenticatee and the caller the authenticator.
  5. (Optional) The original caller reads its own /etc/ppp/pap-secrets to verify the identity of the remote peer.
    Note - If the original caller does require authentication credentials from the remote peer, Step 1 and Step 4 happen in parallel.
    If the peer is authenticated, negotiation continues. Otherwise, the link is dropped.
  6. Negotiation between caller and peer continues until the link is successfully established.
You can add the login option for authenticating PAP credentials to any PPP configuration file. When login is specified, for example, in /etc/ppp/options, pppd verifies that the caller's PAP credentials exist in the password database. The following shows the format of a /etc/ppp/pap-secrets file with the login option.
joe    *  ""  *
sally  *  ""  *
sue    *  ""  *
The parameters have the following meanings.
Caller
joe, sally, and sue are the names of the authorized callers.
Server
Asterisk (*), which indicates that any server name is valid. The name option is not required in the PPP configuration files.
Password
Double quotes, which indicate that any password is valid.
If a password is in this column, then the password from the peer must match both the PAP password and the UNIX passwd database.
IP Addresses
Asterisk (*), which indicates that any IP address is allowed.
CHAP authentication uses the notion of the challenge and response, which means that the peer (authenticator) challenges the caller (authenticatee) to prove its identity. The challenge includes a random number and a unique ID that is generated by the authenticator. The caller must use the ID, random number, and its CHAP security credentials to generate the proper response (handshake) to send to the peer.
CHAP security credentials include a CHAP user name and a CHAP “secret.” The CHAP secret is an arbitrary string that is known to both the caller and the peer before they negotiate a PPP link. You configure CHAP security credentials in the CHAP database, /etc/ppp/chap-secrets.
The CHAP database is implemented in the /etc/ppp/chap-secrets file. Machines on both sides of the PPP link must have each others' CHAP credentials in their /etc/ppp/chap-secrets files for successful authentication.
Note - Unlike PAP, the shared secret must be in the clear on both peers. You cannot use crypt, PAM, or the PPP login option with CHAP.
The /etc/ppp/chap-secrets file has the following syntax.
myclient myserver secret5748 *
The parameters have the following meanings:
myclient
CHAP user name of the caller. This name can be the same as or different from the caller's UNIX user name.
myserver
secret5748
Caller's CHAP secret.
Note - Unlike PAP passwords, CHAP secrets are never sent over the link. Rather, CHAP secrets are used when the local machines compute the response.
CHAP authentication occurs in the following sequence.
Figure 22-2 CHAP Authentication Sequence
  1. Two peers that are about to initiate communications agree on a secret to be used for authentication during negotiation of a PPP link.
  2. The administrators of both machines add the secret, CHAP user names, and other CHAP credentials to the /etc/ppp/chap-secrets database of their respective machines.
  3. The caller (authenticatee) calls the remote peer (authenticator).
  4. The authenticator generates a random number and an ID, and sends this data to the authenticatee as a challenge.
  5. The authenticatee looks up the peer's name and secret in its /etc/ppp/chap-secrets database.
  6. The authenticatee calculates a response by applying the MD5 computational algorithm to the secret and the peer's random number challenge. Then the authenticatee sends the results as its response to the authenticator.
  7. The authenticator looks up the authenticatee's name and secret in its /etc/ppp/chap-secrets database.
  8. The authenticator calculates its own figure by applying MD5 to the number that was generated as the challenge and the secret for the authenticatee in /etc/ppp/chap-secrets.
  9. The authenticator compares its results with the response from the caller. If the two numbers are the same, the peer has successfully authenticated the caller, and link negotiation continues. Otherwise the link is dropped.
