Skip Navigation Links | |
Exit Print View | |
System Administration Guide: Network Services Oracle Solaris 10 8/11 Information Library |
Part I Network Services Topics
Part II Accessing Network File Systems Topics
4. Managing Network File Systems (Overview)
5. Network File System Administration (Tasks)
6. Accessing Network File Systems (Reference)
8. Planning and Enabling SLP (Tasks)
10. Incorporating Legacy Services
Part V Serial Networking Topics
15. Solaris PPP 4.0 (Overview)
16. Planning for the PPP Link (Tasks)
17. Setting Up a Dial-up PPP Link (Tasks)
18. Setting Up a Leased-Line PPP Link (Tasks)
19. Setting Up PPP Authentication (Tasks)
20. Setting Up a PPPoE Tunnel (Tasks)
21. Fixing Common PPP Problems (Tasks)
22. Solaris PPP 4.0 (Reference)
Using PPP Options in Files and on the Command Line
How PPP Configuration File Privileges Work
/etc/ppp/options Configuration File
/etc/ppp/options.tmpl Template
Where to Find Examples of the /etc/ppp/options Files
/etc/ppp/options.ttyname Configuration File
Using /etc/ppp/options.ttyname on a Dial-in Server
Using /etc/ppp/options.ttyname on a Dial-out Machine
options.ttya.tmpl Template File
Where to Find Examples of the /etc/ppp/options.ttyname Files
Configuring User-Specific Options
Configuring $HOME/.ppprc on a Dial-in Server
Configuring $HOME/.ppprc on a Dial-out Machine
Specifying Information for Communicating With the Dial-in Server
/etc/ppp/peers/myisp.tmpl Template File
Where to Find Examples of the /etc/ppp/peers/peer-name Files
Configuring Modem Speed for a Dial-up Link
Defining the Conversation on the Dial-up Link
/etc/ppp/myisp-chat.tmpl Chat Script Template
Modem Chat Script for Calling an ISP
Basic Chat Script Enhanced for a UNIX-Style Login
Chat Script for External ISDN TA
How to Invoke a Chat Script (Task)
Creating a Chat File That Is Executable
How to Create an Executable Chat Program
Authenticating Callers on a Link
Password Authentication Protocol (PAP)
What Happens During PAP Authentication
Using the login Option With /etc/ppp/pap-secrets
Challenge-Handshake Authentication Protocol (CHAP)
What Happens During CHAP Authentication
Creating an IP Addressing Scheme for Callers
Assigning Dynamic IP Addresses to Callers
Assigning Static IP Addresses to Callers
Assigning IP Addresses by sppp Unit Number
Creating PPPoE Tunnels for DSL Support
Files for Configuring Interfaces for PPPoE
Examples of sppptun Commands for Administering Interfaces
PPPoE Access Server Commands and Files
Using PPPoE and PPP Files to Configure an Access Server
PPPoE Client Commands and Files
/etc/ppp/peers/peer-name File for Defining an Access Server Peer
23. Migrating From Asynchronous Solaris PPP to Solaris PPP 4.0 (Tasks)
25. Administering UUCP (Tasks)
Part VI Working With Remote Systems Topics
27. Working With Remote Systems (Overview)
28. Administering the FTP Server (Tasks)
29. Accessing Remote Systems (Tasks)
Part VII Monitoring Network Services Topics
To communicate with a dial-in server, you need to gather information about the server. Then edit a few files. Most significantly, you must configure the communications requirements of all dial-in servers that the dial-out machine needs to call. You can specify options about a dial-in server, such as an ISP phone number, in the /etc/ppp/options.ttyname file. However, the optimum place to configure peer information is in /etc/ppp/peers/peer-name files.
Note - The /etc/ppp/peers/peer-name file is not needed on the dial-out machine for Solaris PPP 4.0 to work correctly.
Use the /etc/ppp/peers/peer-name file to provide information for communicating with a particular peer. /etc/ppp/peers/peer-name allows ordinary users to invoke preselected privileged options that users are not allowed to set.
For example, a nonprivileged user cannot override the noauth option if noauth is specified in the /etc/ppp/peers/peer-name file. Suppose the user wants to set up a link to peerB, which does not provide authentication credentials. As superuser, you can create a /etc/ppp/peers/peerB file that includes the noauth option. noauth indicates that the local machine does not authenticate calls from peerB.
The pppd daemon reads /etc/ppp/peers/peer-name when pppd encounters the following option:
call peer-name
You can create a /etc/ppp/peers/peer-name file for each target peer with which the dial-out machine needs to communicate. This practice is particularly convenient for permitting ordinary users to invoke special dial-out links without needing root privileges.
Typical options that you specify in /etc/ppp/peers/peer-name include the following:
user user-name
Supply user-name to the dial-in server, as the login name of the dial-out machine, when authenticating with PAP or CHAP.
remotename peer-name
Use peer-name as the name of the dial-in machine. remotename is used in conjunction with PAP or CHAP authentication when scanning the /etc/ppp/pap-secrets or /etc/ppp/chap-secrets files.
connect "chat chat_script..."
Open communication to the dial-in server by using the instructions in the chat script.
noauth
Do not authenticate the peer peer-name when initiating communications.
noipdefault
Set the initial IP address that is used in negotiating with the peer to 0.0.0.0. Use noipdefault when setting up a link to most ISPs to help facilitate IPCP negotiation between the peers.
defaultroute
Install a default IPv4 route when IP is established on the link.
See the pppd(1M) man page for more options that might apply to a specific target peer.
The /etc/ppp/peers/myisp.tmpl file contains helpful comments about the /etc/ppp/peers/peer-name file. The template concludes with common options that you might use for an /etc/ppp/peers/peer-name file:
connect "/usr/bin/chat -f /etc/ppp/myisp-chat" user myname remotename myisp noauth noipdefault defaultroute updetach noccp
To use /etc/ppp/peers/myisp.tmpl at your site, rename /etc/ppp/peers/myisp.tmpl to /etc/ppp/peers/.peer-name. Replace peer-name with the name of the peer to be called. Then modify the file contents as needed by your site.
To find examples of the /etc/ppp/peers/peer-name files, refer to the following:
For a dial-out machine, see How to Define the Connection With an Individual Peer.
For a local machine on a leased line, see How to Configure a Machine on a Leased Line.
For support of PAP authentication on a dial-out machine, see How to Add PAP Support to the PPP Configuration Files (Dial-out Machine).
For support of CHAP authentication on a dial-out machine, see How to Add CHAP Support to the PPP Configuration Files (Dial-out Machine).
For support of PPPoE on a client system, see Setting Up the PPPoE Client.
