Skip Navigation Links
Exit Print View
Oracle Solaris Administration: IP Services     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
Part I TCP/IP Administration
1.  Planning the Network Deployment
2.  Considerations When Using IPv6 Addresses
3.  Configuring an IPv4 Network
4.  Enabling IPv6 on the Network
5.  Administering a TCP/IP Network
6.  Configuring IP Tunnels
7.  Troubleshooting Network Problems
8.  IPv4 Reference
9.  IPv6 Reference
Part II DHCP
10.  About DHCP (Overview)
11.  Administering the ISC DHCP Service
12.  Configuring and Administering the DHCP Client
13.  DHCP Commands and Files (Reference)
Part III IP Security
14.  IP Security Architecture (Overview)
15.  Configuring IPsec (Tasks)
16.  IP Security Architecture (Reference)
17.  Internet Key Exchange (Overview)
18.  Configuring IKE (Tasks)
19.  Internet Key Exchange (Reference)
20.  IP Filter in Oracle Solaris (Overview)
21.  IP Filter (Tasks)
Part IV Networking Performance
22.  Integrated Load Balancer Overview
23.  Configuration of Integrated Load Balancer (Tasks)
24.  Virtual Router Redundancy Protocol (Overview)
25.  VRRP Configuration (Tasks)
26.  Implementing Congestion Control
Part V IP Quality of Service (IPQoS)
27.  Introducing IPQoS (Overview)
28.  Planning for an IPQoS-Enabled Network (Tasks)
29.  Creating the IPQoS Configuration File (Tasks)
30.  Starting and Maintaining IPQoS (Tasks)
31.  Using Flow Accounting and Statistics Gathering (Tasks)
32.  IPQoS in Detail (Reference)
IPQoS Architecture and the Diffserv Model
Classifier Module
IPQoS Selectors
Meter Module
tokenmt Metering Module
tswtclmt Metering Module
Marker Module
Using the dscpmk Marker for Forwarding Packets
Using the dlcosmk Marker With VLAN Devices
flowacct Module
flowacct Parameters
Flow Table
flowacct Records
Using acctadm with the flowacct Module
action Statement
Module Definitions
class Clause
filter Clause
params Clause
ipqosconf Configuration Utility
Glossary
Index
This section contains full details about the parts of the IPQoS configuration file. The IPQoS boot-time activated policy is stored in the file /etc/inet/ipqosinit.conf. Although you can edit this file, the best practice for a new IPQoS system is to create a configuration file with a different name. Tasks for applying and debugging an IPQoS configuration are in Chapter 29, Creating the IPQoS Configuration File (Tasks).
The syntax of the IPQoS configuration file is shown in Example 32-3. The example uses the following conventions:
Example 32-3 Syntax of the IPQoS Configuration File
file_format_version ::= fmt_version version
action_clause ::= action {
     name action-name
     module module-name
     params-clause |  ""
     cf-clauses
action_name ::= string
module_name ::= ipgpc | dlcosmk | dscpmk | tswtclmt | tokenmt | flowacct
params_clause ::= params {
     parameters
     params-stats |   ""
parameters ::=    prm-name-value parameters |  ""
prm_name_value ::= param-name param-value
params_stats ::= global-stats boolean
cf_clauses ::= class-clause cf-clauses |
               filter-clause cf-clauses | ""
class_clause ::= class {
     name class-name
     next_action next-action-name
     class-stats | ""
class_name  ::= string
next_action_name  ::= string
class_stats ::= enable_stats boolean
boolean ::= TRUE | FALSE
filter_clause ::= filter {
                name filter-name
                class class–name
                parameters
filter_name ::= string
The remaining text describes each major part of the IPQoS configuration file.
action Statement
You use action statements to invoke the various IPQoS modules that are described in IPQoS Architecture and the Diffserv Model.
When you create the IPQoS configuration file, you must always begin with the version number. Then, you must add the following action statement to invoke the classifier:
fmt_version 1.0
action {
    module ipgpc
    name ipgpc.classify
Follow the classifier action statement with a params clause or a class clause.
Use the following syntax for all other action statements:
action {
name action-name
module module-name
params-clause | ""
cf-clauses
name action_name
Assigns a name to the action.
module module_name
Identifies the IPQoS module to be invoked, which must be one of the modules in Table 32-5.
params_clause
Can be parameters for the classifier to process, such as global statistics or the next action to process.
cf_clauses
A set of zero or more class clauses or filter clauses
Module Definitions
The module definition indicates which module is to process the parameters in the action statement. The IPQoS configuration file can include the following modules.
Table 32-5 IPQoS Modules
Module Name
Definition
ipgpc
IP classifier
dscpmk
Marker to be used to create DSCPs in IP packets
dlcosmk
Marker to be used with VLAN devices
tokenmt
Token bucket meter
tswtclmt
Time-sliding window meter
flowacct
Flow-accounting module
class Clause
You define a class clause for each class of traffic.
Use this syntax to define the remaining classes in the IPQoS configuration:
class {
      name class-name
To enable statistics collection on a particular class, you must first enable global statistics in the ipgpc.classify action statement. For more information, refer to action Statement.
Use the enable_stats TRUE statement whenever you want to turn on statistics collection for a class. If you do not need to gather statistics for a class, you can specify enable_stats FALSE. Alternatively, you can eliminate the enable_stats statement.
Traffic on an IPQoS-enabled network that you do not specifically define is relegated to the default class.
filter Clause
Filters are made up of selectors that group traffic flows into classes. These selectors specifically define the criteria to be applied to traffic of the class that was created in the class clause. If a packet matches all selectors of the highest-priority filter, the packet is considered to be a member of the filter's class. For a complete list of selectors that you can use with the ipgpc classifier, refer to Table 32-1.
You define filters in the IPQoS configuration file by using a filter clause, which has the following syntax:
filter {
       name filter-name
       class class-name
       parameters (selectors)
params Clause
The params clause contains processing instructions for the module that is defined in the action statement. Use the following syntax for the params clause:
params {
           parameters
           params-stats | ""
In the params clause, you use parameters that are applicable to the module.
The params-stats value in the params clause is either global_stats TRUE or global_stats FALSE. The global_stats TRUE instruction turns on UNIX style statistics for the action statement where global statistics is invoked. You can view the statistics by using the kstat command. You must enable action statement statistics before you can enable per-class statistics.
