This chapter contains the following topics:
Section 1.1, "JD Edwards EnterpriseOne Solution Explorer Overview"
Section 1.2, "JD Edwards EnterpriseOne Solution Explorer Implementation"
Oracle's JD Edwards EnterpriseOne Solution Explorer provides you with a convenient method for accessing Windows-based JD Edwards EnterpriseOne applications, and creating/maintaining JD Edwards EnterpriseOne task views for Web or Windows.
JD Edwards EnterpriseOne Solution Explorer is comprised of the following three modes:
Menu Design Mode
Use the Menu Design Mode to set up menus, tasks, task views, and task view roles.
Menu Filtering Mode
Use the Menu Filter Mode to enable and disable tasks users assigned a certain role can perform.
Task Launching Mode
Use the Task Launching Mode to navigate to development and administrative applications in JD Edwards EnterpriseOne using the Fast Path, or using the menu.
This section provides an overview of the steps that are required to implement JD Edwards EnterpriseOne Solution Explorer.
In the planning phase of your implementation, take advantage of all JD Edwards sources of information, including the installation guides and troubleshooting information.
This list displays the steps for the JD Edwards EnterpriseOne Solution Explorer implementation.
Set up task views.
Set up tasks.
See Setting Up Tasks.
Set up task view roles.
