Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Host Serial Console Log Properties
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Oracle Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Managing Oracle Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Oracle Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
Supported CLI Syntax
Basic CLI Commands and Options
Basic Command-Line Editing Keystrokes
CLI Reference For Executing Commands to Change Properties
Executing Commands to Change Target Properties
Executing Commands That Require Confirmation
CLI Reference For Mapping Management Tasks to CLI Targets
Management Connection Tasks and Applicable CLI Targets
Network Deployment Tasks and Applicable CLI Targets
User Management Tasks and Applicable CLI Targets
System Power-On Policy Tasks and Applicable CLI Targets
System Power Usage Policy Tasks and CLI Targets
Firmware Update Tasks and Applicable CLI Targets
Firmware Back Up and Restore Tasks and Applicable CLI Targets
x86 BIOS Back Up and Restore Tasks and Applicable CLI Targets
System Health Status Tasks and Applicable CLI Targets
Event and Audit Log Tasks and Applicable CLI Targets
Alert Notification Tasks and Applicable CLI Targets
Host Server Management Tasks and Applicable CLI Targets
Remote KVMS Service State Tasks and Applicable CLI Target
Host Serial Console Session Tasks and Applicable CLI Target
Host Diagnostic Tasks and Applicable CLI Targets
Fault Management Shell Session Task and Applicable CLI Target
NEM Service Action Tasks and Applicable CLI Target
Server Blade SAS Zoning Tasks and Applicable CLI Target
CMM Blade Management Tasks and Applicable CLI Target
CLI Legacy Service State Tasks and Applicable CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
SNMP Command-Line Syntax Examples
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Oracle ILOM 3.1 Known Issues
Documentation Titles in Translated Documents
Glossary
Index
Use the following table to help identify the applicable CLI namespace targets for Oracle ILOM management connection tasks.
For additional information about setting up a management connection to Oracle ILOM, see the topics listed in the Related Information section that appears after the table.
Note - Not all CLI management connection targets are available on all managed systems.
Task
Description
Targets Containing the Necessary Properties
User Role Required to Configure Properties
Configure the Oracle ILOM Ethernet port.
  • Enable/disable Ethernet access
  • Select to use the service processor NET MGT port or a host network port (not supported on all systems)
/SP/network
or
/CMM/network
Admin (a)
Configure the Oracle ILOM NET MGT Ethernet port for IPv4.
  • Configure the port for DHCP
  • Configure the port for static IP
/SP/network
or
/CMM/network
Admin (a)
For dual-stack IPv4/IPv6, configure the Oracle ILOM NET MGT Ethernet port for IPv6.
  • Configure the port for autoconfiguration
  • Configure the port for DHCPv6
  • Configure a static IPv6 address for the port
  • View IPv6 dynamic addresses
/SP/network
  • ipv6
or
/CMM/network
  • ipv6
Admin (a)
Test the network port.
  • Send an IPv4 or IPv6 test ping
/SP/network
  • test
or
/CMM/network
  • test
Read only (o)
Configure domain name service (DNS) resolution support for Oracle ILOM.
  • Enable DNS resolution
  • Configure the IP address for the name server
  • Configure the domain search path
  • Configure name search attempts
/SP/clients
  • dns
Admin (a)
Configure the Oracle ILOM internal USB Ethernet port.
  • Configure the interconnect port for host management (recommended)
  • Configure the interconnect port for static IP
/SP/network
  • interconnect
Admin (a)
Configure the Oracle ILOM SER MGT serial port.
  • Configure the external SER MGT port settings
  • Configure host internal port settings
  • Pass ownership of the SER MGT port between the service processor and the host
Note - Passing ownership of the SER MGT port to the host should be done only if an Ethernet connection to Oracle ILOM is also available.
/SP/serial
  • external
  • host
  • portsharing
Admin (a)
Related Information
