Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Management Access Deployment Options
Connectivity Deployment Options
Use of Web Server Certificates and SSH Server-Side Keys
Default Timeout for CLI and Web Sessions
Displaying Banner Messages at Log-In
Input Format for IPv4 and IPv6 Addresses
Serial Management Port Owner
Default Network Ports Used by Oracle ILOM
Legacy Sun Servers Not Supporting IPv6
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Example: Set Up DDNS Configuration
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Resolving Web Browser Security Settings
Modify Default Web Server Properties to Support Internet Explorer 6
Resolving Connectivity Issues
Recommended Practice for Spanning Tree Configurations
Test IPv4 and IPv6 Connectivity
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Sun Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Managing Sun Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Sun Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Configuring Telemetry Harness Daemon (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Oracle ILOM 3.1 Known Issues
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Documentation Titles in Translated Documents
Glossary
Index
Modifying Default Management Access Configuration Properties
Network administrators can optionally accept or modify the default management access properties shipped
with Oracle ILOM. To modify the default management access properties in Oracle ILOM, see
the following tables:
Table 35 Web Server Configuration Properties
HTTP Webserver (http/ securedirect=enabled servicestate=disabled) |
Redirect Connection to HTTPS
Redirect Connection to HTTPS | Enabled | DisabledWhen the HTTP Webserver property is set to Redirect Connection to HTTPS,
the service state property for HTTPS Webserver is automatically enabled. These default property
values instruct Oracle ILOM to use HTTPS to securely transmit information to the
web server. When the HTTP Webserver property is set to enabled, Oracle ILOM uses
HTTP a non-encrypted protocol to transmit information to the web server. When the
HTTP Webserver property is set to disabled, the use of the transmitting information
to the web server using HTTP is disabled in Oracle ILOM. CLI Syntax for HTTP Web Server: set /SP|CMM/services/http securedirect=enabled|disabled servicestate=disabled|enabled |
80 |
80
| User_definedWhen the HTTP service state is enabled, Oracle ILOM by default, communicates with
the web server using HTTP over TCP port 80. If necessary, the default
port number can be changed. CLI Syntax for HTTP Port: set /SP|CMM/services/http port=<n> |
HTTP Session Timeout (http/ sessiontimeout=) |
15 seconds |
15 seconds | User_definedThe HTTP web session
timeout determines how many minutes until an inactive web browser client is automatically
logged out. The default HTTP web session timeout is 15 minutes. If necessary,
the default session timeout value can be increased or decreased. CLI Syntax for HTTP Session Timeout: set /SP|CMM/services/http sessiontimeout=<n> |
HTTPS Webserver (https/ servicestate=enabled) |
Enabled |
the HTTPS Webserver property is set to enabled, Oracle ILOM uses HTTPS to
securely transmit information to the web server. When the HTTPS Webserver property
is set to disabled, the use of transmitting information to the web server
using HTTPS is disabled in Oracle ILOM. CLI Syntax for HTTPS Web Server: set /SP|CMM/services/https servicestate=enabled|disabled |
443 |
443 | User_definedWhen the HTTPS service
state is enabled, Oracle ILOM, by default, communicates with the web server using
HTTPS over TCP port 443. If necessary, the default port number can be
changed. HTTPS Port CLI Syntax: set /SP|CMM/services/https port=<n> |
HTTPS Session Timeout (https/sessiontimeout=) |
15 seconds |
15 seconds | User_definedThe HTTPS web session timeout determines how
many minutes until an inactive web browser client is automatically logged out. The default
HTTPS web session timeout is 15 minutes. If necessary, the default session timeout
value can be increased or decreased. CLI Syntax for HTTPS Session Timeout: set /SP|CMM/services/https sessiontimeout=<n> |
SSLv2 ( https/ sslv2=disabled) |
Disabled |
Disabled | EnabledThe SSLv2 property is disabled
by default. If necessary, the default SSLv2 property can be enabled. CLI Syntax for SSLv2: set /SP|CMM/services/https sslv2=disabled|enabled |
SSLv3 (https/ sslv3=enabled) |
Enabled |
Enabled | DisabledOracle ILOM
by default uses SSLv3 and TLSv1 to enable the strongest secure socket layer
encryption. If necessary, the default SSLv3 property can be disabled. CLI Syntax for SSLv3: set /SP|CMM/services/https sslv3=enabled|disabled |
TLSv1 (https/ tlsv1=enabled) |
Enabled |
Enabled | DisabledOracle ILOM by
default uses SSLv3 and TLSv1 to enable the strongest secure socket layer encryption.
If necessary, the default TLSv1 property can be disabled. CLI Syntax for TLSv1: set /SP|CMM/services/https tlsv1=enabled|disabled |
Weak Ciphers (https/ weak_ciphers=disabled) |
Disabled |
Weak Ciphers property is disabled by default. It might be necessary to enable
weak ciphers to support the use of older web browsers. CLI Syntax for Weak Ciphers: set /SP|CMM/services/https weak_ciphers=disabled|enabled Related Information:
Save |
Web interface – To apply
changes made to properties within the Web Server Settings page, you must click
Save. |
Table 36 SSL Certificate and Private Key Configuration Properties for HTTPS Web Server
Certificate File Status (certstatus=) |
Using Default
(No custom certificate or private key loaded) |
Default_Certificate | Custom_CertificateThe Certificate Status property is a read-only
property. This property indicates which of the following types of SSL certificates is currently
in use by the HTTPS web server:
Note – When the default SSL certificate is
in use, users connecting to the Oracle ILOM web interface for the first
time are notified of the default self-signed certificate and are prompted to accept
its use. The default self-signed SSL certificate ensures that all communication between a
web browser client and the Oracle ILOM SP (or CMM) is fully encrypted. CLI Syntax to Show Certificate Status: show /SP|CMM/https/ssl |
Custom
Certificate Load (/custom_certificate) |
Web interface – Click the Load Certificate button to upload the Custom Certificate
file that is designated in the File Transfer Method properties. Note. A valid custom certificate
configuration requires the uploading of a custom certificate and a custom private key.
Only then will the custom SSL certificate configuration apply and be persistent across
system reboots and Backup and Restore operations. CLI Syntax to Load Custom Certificate: load_uri=file_transfer_method://host_address/file_path/custom_certificate_filename |
Where f ile_transfer_method can include: Browser| TFTP| FTP| SCP|HTTP |HTTPS| PasteFor a detailed
description of each file transfer method (excluding Paste), see Supported File Transfer Methods. |
Custom Certificate Remove (/custom_certicate clear_action=true) |
Remove Certificate Button to remove the Custom SSL Certificate file presently stored in
Oracle ILOM. When prompted, click Yes to delete or No to cancel action. CLI Syntax to Remove Certificate: set /SP|CMM/services/https/ssl/custom_certificate clear_action=true When
prompted, type y to delete or n to cancel action. |
Custom Private Key (/custom_key) |
Web interface –
Click the Load Custom Private Key button to upload the Custom Private Key file
system reboots and Backup and Restore operations. CLI Syntax to Load Custom Private Key: load_uri=file_transfer_method://host_address/file_path/custom_key_filename |
Where file_transfer_method can include: Browser| TFTP| FTP| SCP|HTTP |HTTPS| PasteFor a detailed
Custom Private Key Remove (/custom_key clear_action=true) |
Remove Custom Private Key button to remove the Custom Private Key file presently
stored in Oracle ILOM. When prompted, click Yes to delete or No to
cancel the action. CLI Syntax to Remove Certificate Private Key: set /SP|CMM/services/https/ssl/custom_key clear_action=true When prompted, type y to delete or n to cancel the
action. |
Table 37 SNMP Configuration Properties
Enabled |
Enabled | DisabledThe SNMP State property
is enabled by default. When this property is enabled, and the properties for
one or more user accounts or communities for SNMP are configured, the SNMP
management service in Oracle ILOM is available for use. When the SNMP State property
is disabled, the SNMP port is blocked, prohibiting all SNMP communication between Oracle
ILOM and the network. CLI Syntax for SNMP State: set /SP|CMM/services/snmp state=enabled|disabled |
161 |
161 | User_specified.Oracle ILOM, by default, uses TCP port 161
to transmit SNMP communication between an Oracle ILOM SP (or Oracle ILOM CMM)
and the network. If necessary, the default port property number can be changed. CLI Syntax for SNMP Port: set /SP|CMM/services/snmp port=n |
Engine ID (engineid=) |
Auto-set
by SNMP agent |
The Engine ID property is automatically set by the Oracle ILOM
SNMP agent. This ID is unique to each Oracle ILOM SNMP enabled-system. Although the
Engine ID is configurable, the ID should always remain unique across the data
center for each Oracle ILOM system. Only experienced SNMP users who are familiar
with SNMP v3 security should modify the SNMP Engine ID property. |
Set Requests (sets=) |
Disabled |
Set Requests property is disabled in Oracle ILOM by default. When the Sets
Requests property is disabled, the following SNMP MIBs are available for monitoring purposes:
SUN-HW-TRAP-MIB – Use this MIB to monitor trap notifications for hardware-related events such as faults.
SUN-PLATFORM-MIB – Use this MIB to poll hardware-related information such as inventory and health.
When
the Set Requests property is enabled, the MIBs described above are available for
monitoring purposes and the following MIBs are available for management purposes:
SUN-HW-CTRL-MIB – Use this MIB to configure hardware policies such as power management.
SUN-ILOM-CONTROL-MIB – Use this MIB to configure Oracle ILOM features such as creating users and configuring services.
CLI Syntax for Set Requests: set /SP|CMM/services/snmp sets=disabled|enabled Related Information:
Protocols (v1|v2c|v3) |
v3, Enabled |
v1| v2c| v3Oracle ILOM,
by default, enables the use of SNMP v3 and disables the use of
SNMP v1 and v2c. SNMPv1 and v2c do not support encryption and
use community strings as a form of authentication. SNMPv3 uses encryption to provide a
secure channel and uses individual user names and passwords that are stored securely
on the SNMP management station. If necessary, the default SNMP Protocol property value
is configurable.
Note - Use SNMP v2c or v3 for monitoring purposes and keep the default property
disabled for Set Requests.
CLI Syntax to Modify Default Protocol: set /SP|CMM/services/snmp v1|v2c|v3=enabled|disabled |
Save |
Web interface – To apply changes made to properties within the
SNMP Management page, you must click Save. |
SNMP Communities (/communities) |
Community Name | Permission= Read-only (ro)| Read-write (rw) SNMP
communities apply only to SNMP v1 or v2c to control user access and
authorization levels in Oracle ILOM. When the Protocols property for SNMP v1 or
v2c is enabled, the properties for SNMP communities are configurable in Oracle ILOM.
The following rules apply when configuring communities:
Community name – Up to 35 characters in length, must start with an alphabetic character, and must not contain any spaces
Save (web interface only) – All changes made within the SNMP Add SNMP User dialog must be saved
CLI Syntax to Create SNMP Communities: create /SP|CMM/services/snmp/communities name=community_name permission=rw|ro show /SP|CMM/services/snmp/communities public|private delete /SP|CMM/services/snmp/communities community_name |
Username | Authentication Password | Permission| Authentication Protocol
| Privacy ProtocolSNMP Users apply only to SNMP v3 to control user access
and authorization levels in Oracle ILOM. When the Protocol property for SNMP v3 is
enabled, the properties for SNMP users are configurable in Oracle ILOM. The following rules
apply when configuring SNMP users:
User name – Up to 35 characters in length, must start with an alphabetic character, and must not contain any spaces
Authentication or privacy password – Up to 16 characters in length, case-sensitive, no colons, no spaces, and password must be confirmed
Save (web interface only – All changes made within the SNMP Add SNMP User dialog must be saved.
CLI Syntax to Create SNMP Users: create /SP|CMM/services/snmp/users username=value authenticationprotocol=MD5|SHA authenticationpassword=value permissions=ro|rw privacyprotocol=aes|des|none show /SP|CMM/services/snmp/users delete /SP|CMM/services/snmp/username |
MIBs Download (/mibs dump_uri=) |
Oracle ILOM provides the ability to download the
SUN SNMP MIBs directly from the server SP or CMM. |
Table 38 SSH Server Configuration Properties
Enabled |
Enabled | DisabledThe SSH Server State property is enabled by default. When
the SSH Server State property is enabled, the SSH server uses server-side keys
to permit remote clients to securely connect to the Oracle ILOM SP (or
Oracle ILOM CMM) using a command-line interface. When the SSH Server State property is
disabled or restarted, all CLI SP or CLI CMM sessions running over SSH
are automatically terminated. Note. Oracle ILOM automatically generates the SSH Server side keys on the
first boot of a factory default system. Web interface: Changes to the SSH Server State
in the web interface do not take affect in Oracle ILOM until you
click Save. CLI Syntax for SSH Server State: set /SP|CMM/services/ssh state=enabled|disabled |
Restart Button (restart_sshd_action=) |
True| FalseRestarting the SSH server will automatically: (1) terminate all connected SP
or CMM CLI sessions, as well as (2) activate newly pending server-side key(s). CLI Syntax for Restart: set /SP|CMM/services/ssh restart_sshd_action=true |
Generate
RSA Key Button (generate_new_key_type=rsa generate_new_key_action= true) |
Provides the ability to generate a new RSA SSH key. CLI Syntax for Generate RSA Key: set /SP|CMM/services/ssh generate_new_key_type=rsa generate_new_key_action=true |
Generate DSA
Key Button (generate_new_key_type=dsa generate_new_key_action=) |
Provides the ability to generate a new DSA SSH key. CLI Syntax for Generate DSA Key: set /SP|CMM/services/ssh generate_new_key_type=dsa generate_new_key_action=true |
Table 39 IPMI Service Configuration Properties
Enabled |
Enabled | DisabledThe State property for IPMI v2 is enabled by default. When the
IPMI State property is enabled, Oracle ILOM permits remote IPMItool clients to securely
connect to the Oracle ILOM SP (or Oracle ILOM CMM) using a command-line
interface. When the IPMI State property is disabled, all IPMItool clients connected to the
SP or CMM through the Oracle ILOM CLI are automatically terminated. Web interface: Changes to
the IPMI State in the web interface do not take affect in Oracle
ILOM until you click Save. CLI Syntax for IPMI State: set /SP|CMM/services/ipmi state=enabled|disabled |
Table 40 CLI Session Timeout Configuration Property
Session Timeout (timeout=) |
Disabled |
Disabled | Enabled, minutes=nThe CLI
Session Timeout property determines how many minutes until an inactive CLI session is
automatically logged out. By default, there is no CLI timeout configured. If
the Oracle ILOM CLI is used on a shared console, network administrators are recommended
to set the CLI session timeout value to 15 minutes or less. Web interface:
Changes to the CLI session timeout properties in the web interface do not
take affect in Oracle ILOM until you click Save. CLI Syntax for CLI Session Timeout: set /SP|CMM/cli timeout=enabled|disabled minutes=value |
Table 41 WS-Man Web Service Configuration Properties
Enabled |
Enabled | DisabledThe WS-Man web service State property is enabled by
default. If necessary, the WS-Man web service state can be disabled. Web interface: Changes to
the WS-Man state in the web interface do not take affect in Oracle
ILOM until you click Save. CLI Syntax for WS-Man State: set /SP|CMM/services/wsman state=enabled|disabled Related Information:
HTTP |
HTTP| HTTPSThe Mode property is set to HTTP by
default. To improve security, this default property value can be set to HTTPS.
CLI Syntax for WS-Man Mode: set /SP|CMM/services/wsman mode=http|https |
8889 |
8889 | user_definedWhen the State property is enabled and the Mode property
is set to HTTP, Oracle ILOM uses TCP port 8889 for the WS-Man
web service. If necessary, the default port property value can be changed. CLI Syntax for WS-MAN HTTP Port: set /SP|CMM/services/wsman http_port=n |
8888 |
8888
| user_definedWhen the State property is enabled and the Mode property is set to
HTTPS, Oracle ILOM uses TCP port 8888 for the WS-Man web service. If
necessary, the default port property value can be changed. CLI Syntax for WS-Man HTTPS Port: set /SP|CMM/services/wsman https_port=n |
Table 42 Banner Message Configuration Properties
Connect Message (connect_message=) |
Populate the Connect Message property with content to appear in
the Oracle ILOM interfaces upon connecting to Oracle ILOM. CLI Syntax to Set Connect Message: set /SP/preferences/banner connect_message=<content> |
Login Message (login_message=) |
Populate the Login Message property
with content to appear in the Oracle ILOM interfaces after logging into Oracle
ILOM. CLI Syntax to Set Login Message: set /SP/preferences/banner login_message=<content> |
Login Message Acceptance (login_message_acceptance=) |
Disabled |
Disabled | Enabled Set the Login Banner Acceptance property to enabled to display the
banner message. CLI Syntax for Login Message Acceptance: set /SP/preferences/banner login_message_acceptance=disabled|enabled |
