Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.1 Documentation Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Documentation Feedback
Product Downloads
Download Product Software and Firmware
Oracle ILOM 3.1 Firmware Version Numbering Scheme
Support and Accessibility
Quick Start
Oracle ILOM 3.1 – Quick Start
Factory Default Settings
Mandatory Setup Tasks
Optional Setup Tasks
Daily Management Tasks
Routine Maintenance Tasks
Initial Setup FAQs
Configuration and Maintenance
Setting Up a Management Connection to Oracle ILOM and Logging In
Establishing a Management Connection to Oracle ILOM
Logging In to Oracle ILOM Server SP or CMM
Configuring Oracle ILOM for Maximum Security
Setting Up and Maintaining User Accounts
Managing User Credentials
Configuring Local User Accounts
Configuring Active Directory
Configuring LDAP/SSL
Configuring LDAP
Configuring RADIUS
Modifying Default Settings for Network Deployment and Administration
Network Deployment Principles and Considerations
Modifying Default Management Access Configuration Properties
Modifying Default Connectivity Configuration Properties
Example Setup of Dynamic DNS
Assigning System Identification Information
Setting Properties for SP or CMM Clock
Suggested Resolutions for Network Connectivity Issues
Using Remote KVMS Consoles for Host Server Redirection
First-Time Setup for Oracle ILOM Remote Console
Launching and Using the Oracle ILOM Remote Console
First Time Setup for Oracle ILOM Storage Redirection CLI
Launching and Using the Oracle ILOM Storage Redirection CLI
Starting and Stopping a Host Serial Redirection Session
Configuring Host Server Management Actions
Controlling Host Power to Server or Blade System Chassis
Setting Host Diagnostic Tests to Run
Setting Next Boot Device on x86 Host Server
Setting Boot Behavior on SPARC Host Server
Overriding SPARC Host Boot Mode
Managing SPARC Host Domains
Setting SPARC Host KeySwitch State
Setting SPARC Host TPM State
Setting Up Alert Notifications and Syslog Server for Event Logging
Configuring Alert Notifications
Configuring Syslog for Event Logging
Setting System Management Power Source Policies
Power-On and Cooling-Down Policies Configurable From the Server SP
System Management Power Supply Policies Configurable From CMM
Setting Power Alert Notifications and Managing System Power Usage
Setting Power Consumption Alert Notifications
Setting CMM Power Grant and SP Power Limit Properties
Setting SP Advanced Power Capping Policy to Enforce Power Limit
Setting SP Power Management Settings for Power Policy (SPARC)
Setting the CMM Power Supply Redundancy Policy
Performing Oracle ILOM Maintenance and Configuration Management Tasks
Performing Firmware Updates
Reset Power to Service Processor or Chassis Monitoring Module
Backing Up, Restoring, or Resetting the Oracle ILOM Configuration
Maintaining x86 BIOS Configuration Parameters
BIOS Configuration Management
Performing BIOS Configuration Tasks From Oracle ILOM
SAS Zoning Chassis Blade Storage Resources
Zone Management for Chassis-Level SAS-2 Capable Resources
Manageable SAS-2 Zoning-Capable Devices
Sun Blade Zone Manager Properties
Important SAS Zoning Allocations Considerations
Enabling Zoning and Creating SAS-2 Zoning Assignments
Managing Existing SAS-2 Storage Resource Allocations
Resetting Sun Blade Zone Manager Allocations to Factory Defaults
Resetting the Zoning Password to Factory Default for Third-Party In-Band Management
User's Guide
Oracle ILOM Overview
About Oracle ILOM
Oracle ILOM Features and Functionality
Supported Management Interfaces
Supported Operating System Web Browsers
Integration With Other Management Tools
Getting Started With Oracle ILOM 3.1
Navigating the Redesigned 3.1 Web Interface
Navigating the Command-Line Interface (CLI) Namespace Targets
Collecting System Information, Monitoring Health Status, and Initiating Host Management
Collecting Information, Status, and Initiating Common Actions
Administering Open Problems
Administering Service Actions: Sun Blade Chassis NEMs
Managing Oracle ILOM Log Entries
Performing Commonly Used Host Management Actions (Web)
Applying Host and System Management Actions
Administering Host Management Configuration Actions
Administering System Management Configuration Actions
Real-Time Power Monitoring Through Oracle ILOM Interfaces
Monitoring Power Consumption
Monitoring Power Allocations
Analyzing Power Usage Statistics
Comparing Power History Performance
Troubleshooting Oracle ILOM Managed Devices
Network Connection Issues: Oracle ILOM Interfaces
Tools for Observing and Debugging System Behavior
Enabling and Running Oracle ILOM Diagnostic Tools
Managing Sun Hardware Faults Through the Oracle ILOM Fault Management Shell
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
Using fmadm to Administer Active Sun Hardware Faults
Using fmdump to View Historical Fault Management Logs
Using fmstat to View the Fault Management Statistics Report
Using the Command-Line Interface
About the Command-Line Interface (CLI)
CLI Reference For Supported DMTF Syntax, Command Verbs, Options
CLI Reference For Executing Commands to Change Properties
CLI Reference For Mapping Management Tasks to CLI Targets
CLI Reference
Basic CLI Command Reference for Oracle ILOM 3.1
System Information and Management
Host and System Control
Oracle ILOM Initial Setup
System Monitoring and Status
System Inventory
Oracle ILOM Configuration Management
Oracle ILOM Help
SNMP, IPMI, CIM, WS-MAN Protocol Management
SNMP Overview
About Simple Network Management Protocol
SNMP Components
Oracle ILOM SNMP MIBs
Configuring SNMP Settings in Oracle ILOM
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (CLI)
Managing SNMP Read and Write Access, User Accounts, and SNMP Trap Alerts (Web)
Downloading SNMP MIBs Using Oracle ILOM
Manage User Accounts Using SNMP
Before You Begin – User Accounts (SNMP)
Configuring Oracle ILOM User Accounts (SNMP)
Configuring Oracle ILOM for Active Directory (SNMP)
Manage DNS Name Server Settings (SNMP)
Configuring Oracle ILOM for LDAP (SNMP)
Configuring Oracle ILOM for LDAP/SSL (SNMP)
Configuring Oracle ILOM for RADIUS (SNMP)
Manage Component Information and Email Alerts (SNMP)
Before You Begin – Component Information (SNMP)
Viewing Component Information (SNMP)
Managing Clock Settings, Event Log, Syslog Receiver, and Alert Rules (SNMP)
Configuring SMTP Client for Email Alert Notifications (SNMP)
Configuring Email Alert Settings (SNMP)
Configuring Telemetry Harness Daemon (SNMP)
Monitor and Manage System Power (SNMP)
Before You Begin – Power Management (SNMP)
Monitoring the Power Consumption Interfaces (SNMP)
Maintaining System Power Policy (SNMP)
Managing System Power Properties (SNMP)
Manage Oracle ILOM Firmware Updates (SNMP)
Update Oracle ILOM Firmware (SNMP)
Manage Oracle ILOM Backup and Restore Configurations (SNMP)
View and Configure Backup and Restore Properties (SNMP)
Manage SPARC Diagnostics, POST, and Boot Mode Operations (SNMP)
Before You Begin – Manage SPARC Hosts (SNMP)
Managing SPARC Diagnostic, POST, and Boot Mode Properties (SNMP)
Manage SPARC Host Diagnostic Properties
Manage SPARC Host POST Operations
Manage SPARC Host Boot Mode Properties
Manage SPARC Host Keyswitch Property
Server Managment Using IPMI
Intelligent Platform Management Interface (IPMI)
Configuring the IPMI Service
Using IPMItool to Run ILOM CLI Commands
Performing System Management Tasks (IPMItool)
IPMItool Utility and Command Summary
Server Management Using WS-Management and CIM
WS-Management and CIM Overview
Configuring Support for WS-Management in Oracle ILOM
Supported DMTF SMASH Profiles, CIM Classes and CIM Indications
Oracle's Sun-Supported CIM Classes
Document Conventions for Oracle's Sun-Supported CIM Classes
Oracle_AssociatedIndicatorLED
Oracle_AssociatedSensor
Oracle_Chassis
Oracle_ComputerSystem
Oracle_ComputerSystemPackage
Oracle_Container
Oracle_ElementCapabilities
Oracle_ElementConformsToProfile
Oracle_EnabledLogicalElementCapabilities
Oracle_HWCompErrorOkIndication
Oracle_IndicatorLED
Oracle_InstCreation
Oracle_InstDeletion
Oracle_LogEntry
Oracle_LogManagesRecord
Oracle_Memory
Oracle_NumericSensor
Oracle_PhysicalAssetCapabilities
Oracle_PhysicalComponent
Oracle_PhysicalElementCapabilities
Oracle_PhysicalMemory
Oracle_PhysicalPackage
Oracle_Processor
Oracle_ProcessorChip
Oracle_Realizes
Oracle_RegisteredProfile
Oracle_RecordLog
Oracle_ReferencedProfile
Oracle_Sensor
Oracle_SpSystemComponent
Oracle_SystemDevice
Oracle_ThresholdIndication
Oracle_UseOfLog
SNMP Command Examples
snmpget Command
snmpwalk Command
snmpbulkwalk Command
snmptable Command
snmpset Command
snmptrapd Command
Feature Updates and Release Notes
Feature Enhancements as of Oracle ILOM 3.1
Feature Enhancements Summary
Updates to Oracle ILOM 3.1.x Firmware
Initial 3.1 Point Releases for Servers and Sun Blade 6000 CMM
Oracle ILOM 3.1 Known Issues
Deprecation Notice for WS-Man as of Oracle ILOM 3.2.1
Documentation Titles in Translated Documents
Glossary
Index
Note - You can use the get and set commands to view and configure SPARC host settings. For a description of the MIB objects used in these commands, see the SUN-ILOM-CONTROL-MIB.
  1. Log in to a host that has an SNMP tool and the Oracle ILOM MIBs installed. For example, type:
    ssh username@snmp_manager_ipaddress
    Password: password
  2. Refer to the following SNMP command examples:
    • To view the starting MAC address for the host, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostMACAddress.0
    • To view the version string for OpenBoot PROM (OBP), type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostOBPVersion.0
    • To view the version string for POST, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostPOSTVersion.0
    • To view the option that determines whether the host should continue to boot in the event of a non-fatal POST error, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostAutoRunOnError.0
    • To configure the host to continue to boot in the event of a non-fatal POST error, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostAutoRunOnError.0 i 1
    • To view the string that describes the status of POST, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostPOSTStatus.0
    • To view the option that determines what action the SP will take when it discovers that the host is hung, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostAutoRestartPolicy.0
    • To configure the SP to reset when it discovers that the host is hung, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostAutoRestartPolicy.0 i 2
    • To view the string that describes the boot status of host operating system, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostOSBootStatus.0
    • To view the boot timer time-out value, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootTimeout.0
    • To set the boot timer time-out value to 30 seconds, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootTimeout.0 i 30
    • To view the property that determines what action the SP will take when the boot timer expires, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootRestart.0
    • To configure the SP to reset when the boot timer expires, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootRestart.0 i 2
    • To view the maximum number of boot failures allowed by the SP, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostMaxBootFail.0
    • To set the maximum number of boot failures allowed by the SP to 10, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostMaxBootFail.0 i 10
    • To view the property that determines what action the SP will take when the maximum number of boot failures is reached, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootFailRecovery.0
    • To configure the SP to power cycle the host when the maximum number of boot failures is reached, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostBootFailRecovery.0 i 2
    • To view the version string for the Hypervisor, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostHypervisorVersion.0
    • To view the version string for the system firmware (SysFw), type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostSysFwVersion.0
    • To view the property that determines the break action that the SP will send, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostSendBreakAction.0
    • To configure the SP to send a dumpcore break action, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostSendBreakAction.0 i 3
    • To view the property that determines the host I/O reconfiguration policy to apply on next host power-on, type:
      % snmpget -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostIoReconfigurePolicy.0
    • To configure the SP to execute the host I/O reconfiguration policy on the next power-on, type:
      % snmpset -mALL -v2c -cprivate SNMP_agent_ipaddress ilomCtrlSPARCHostIoReconfigurePolicy.0 i 3
