This chapter discusses:
You can start the Management Agent by using a script that is delivered when the Management Agent is installed. The script resides on the machine on which you installed the Management Agent and is typically located in these platform-dependent directories:
You can use these methods to start the Management Agent:
The Management Agent installer creates a windows service that can be used to start, stop, or restart the Management Agent. This is the format of the service name:
SM Management Agent [install_location\JDE_HOME]
The pathinstallation_directory\JDE_HOME
refers to the install location of the Management Agent.For example:
You can use this .bat
file to start the Management Agent:
installation_directory\JDE_HOME\SCFHA\startAgent.bat
refers to the install location of the Management Agent.You can use this script to start the Management Agent:
installation_directory/JDE_HOME/SCFHA/bin/startAgent
The pathinstallation_directory/JDE_HOME
refers to the install location of the Management Agent.In order for the Management Agent to function, it is required that JDK 1.5 be installed on the IBM i machine.
Start the Management Agent as a Background Job
As shown below, you must use the "&" switch as a suffix for the command script in order to start the Management Agent as a background job. Launching the job in this manner means that when you leave the qshell the job will not die.
User Installing, Starting, or Restarting the Management Agent
The user who installs, starts or restarts the agent must have the minimum permissions of *ALLOBJ, *SAVSYS and *JOBCTL is *SECADM. After the Management Agent installation is complete, it will start. It is important to note that when starting the Management Agent the user that is signed onto the IBM i machine is the user that executes the functionality when the Management Agent is performing Server Manager work. That user must not be a user that has a JD Edwards EnterpriseOne Enterprise Server library in its library list (for example: E900SYS).
For the Management Agent running on the IBM i platform, you can run these commands from the default /JDEdwards/JDE_HOME/SCFHA
folder:
restartAgent
runAgent
startAgent
stopAgent
To submit each command to batch:
To stop, start, or restart the Management Agent, log in to OS400 with a user profile which has sufficient privileges to operate these services.
You should ensure that the job queue that the user belongs to is one that is not interrupted during processing. Because it is interruptible, a job queue such as QINTER might not be the best choice for the job queue in which to run the Management Agent. You should consider this warning when selecting the user with the correct permissions and configuration to run the Management Agent processing tasks.
To submit the Management Agent action (stop, start, or restart) to batch so it runs in a subsystem other than QINTER:
where in this example, the job queue is QTXTSRCH
, which is a job queue that is delivered by IBM. This job queue has no thread limitation and runs in the QBATCH
subsystem.
You can use the work with active jobs command to view the processes running under the QBATCH
subsystem. For example:
If you want to kill the initial startAgent
job, you can issue this command:
cmd: SBMJOB CMD(STRQSH CMD('cd
/JDEdwards/JDE_HOME/SCFHA;./stopAgent &')) JOB(STOPAGENT) JOBQ(QTXTSRCH)
where QTXTSRCH
is the name of the job queue previously started.
To verify the job is killed, you can use this work with active jobs command to view the processes running under the QBATCH subsystem:
cmd: WRKACTJOB SBS(QBATCH)
You can use these methods to stop a Management Agent:
Section 6.2.1, "Stop a Management Agent from the Management Console"
Section 6.2.3, "Stop a Management Agent as a Service (Microsoft Windows only)"
Using the Management Console, Server Manager users with appropriate permissions (refer to Chapter 21, "Administer Management Console Users and User Groups") can stop a specific Management Agent, each of which is uniquely associated with a specific Managed Home. You can specify which Management Agent to stop by checking the check box of the associated Managed Home and then clicking the Stop Agent button on the Management Console.
If a user does not have sufficient privileges to stop a Management Agent, the Stop Agent button on the Management Console is disabled (grayed out).You can stop a Management Agent using a script that resides on the machine on which you installed the Management Agent. Typically the stopAgent
script is located in a platform-dependent directory:
file to stop the Management Agent:
installation_directory\JDE_HOME\SCFHA\stopAgent.bat
refers to the install location of the Management Agent.You can use this script to stop the Management Agent:
refers to the install location of the Management Agent.Use this command within qshell to stop the Management Agent:
JDE_HOME/SCFHA/stopAgent
refers to the install location of the Management Agent.Refer to Start a Management Agent from a Script in this chapter.
You can restart (that is, ”bounce”) a Management Agent that is currently running using a script that resides on the machine on which you installed the Management Agent. Typically the restartAgent
file to restart the Management Agent:
installation_directory\JDE_HOME\SCFHA\restartAgent.bat
refers to the install location of the Management Agent.You can use this script to restart the Management Agent:
refers to the install location of the Management Agent.User Installing, Starting, or Restarting the Management Agent. The user who installs, starts or restarts the agent must have the minimum permissions of *ALLOBJ, *SAVSYS and *JOBCTL is *SECADM. After the Management Agent installation is complete, it will start. It is important to note that when starting the Management Agent the user that is signed onto the IBM i machine is the user that executes the functionality when the Management Agent is performing Server Manager work. That user must not be a user that has a JD Edwards EnterpriseOne Enterprise Server library in its library list (for example: E900SYS).
JDE_HOME/SCFHA/restartAgent
